Question about Maytag Legacy Series Top Load Washer
Sav405deww Tub Capacity
What is the capacity of whirlpool model #LA5558XTW2
This is a direct drive model washer tub size is large capacity but any washer to stop from overloading is loose laid cloths 3/4 of tub any washer to work properly
Dec 19, 2016 | Whirlpool Washing Machines
I am trying to find out how many cu ft my Kenmore Elite HE 4 dryer is. It is no longer made & is not searchable on any sites. The model # is 85089400
7 cubic ft. capacity.
Measure the diameter of the tub using a measuring tape
  1. Divide the diameter by two to get the radius
  2. Measure the height of the tub in feet
  3. Multiply the square of the radius with the height of tub and pi (3.14). (square of radius x height x pi)
The result would be the capacity of dryer in cubic feet.
Jun 14, 2016 | Kenmore Dryers
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    How many cubic feet are in the Kenmore Washer Model 110 80 series
    The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
    Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    I have a Legacy SAV405DEWW machine wont run
    I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
    Jul 20, 2009 | Maytag Legacy Series Top Load Washer
    I have a Kenmore 70 series washer Model 110-20722990. I am trying to find out what kind of tub is in it (plastic or steel) and the capacity. I don't see this info on the washer anywhere. Thanks!
    ceramic coated steel tub - 3.2cu ft capacity.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jun 16, 2009 | Kenmore 20722
    Goes through cycle, but doesn't drain. Will drain manually
    Hi, Sounds like it could be timer. Does the timer advance to the off position? There could be a partial plug in the hose or pump also. You can add water again and then go to spin cycle. Lift the drain hose out of the drain pipe just enough that you can see the water flow. You should see water draining out with a bit of force and the stream should be the sizt of the drain hose.
    I hope this helps you. Please let me know if I can be of more assistance.
    Thanks
    Vic
    May 11, 2009 | Maytag Legacy Series Top Load Washer
    Washing Machines Logo
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
