Question about Clarion CZ501
Clairion cz501 why do my radion cuts off shut down at mid volume
Right channel cuts out when I increase the volume
Blown or defective Headphone Amp IC or alternatively a defective Pot. Either way only AVID can fix it for you.
Outside parts and service is impossible.
Oct 03, 2012 | Digidesign *mbox2...
I'm looking to buy a clairion convector 1500 used if possible don't have much money i live near Mont-tremblant quebec
Apparently, the model you're looking for has been discontinued by the manufacturer. Not sure of the reason why, but we've had a lot of problems posted here on FixYa regarding them. However, there are other models available, by a different manufacturer, that are very similar to the Clairion HC-1500. And they are not expensive. Good deals abound on Ebay. Search for one there under Convection Heaters (All Ebay Categories) www.ebay.com
Hope this helps you find what you need.
Apr 20, 2011 | Clairion Convection Heater - HC-1500
It turns off with an error to Check Speaker wires. It's done this in the past, usual if I push the volume too it's threshold. It would always bounce back. Now it shuts down at just about it's mid-peak...
Did the fact that it was responding negatively to the loud volume not suggest it might be a bad idea to keep doing it?
The threshold on the volume knob is NOT where normal undistorted listening levels are found. Given a normal level of input you could be pushing your amp so hard that it clips or distorts and kills your speakers.
Do what it asks: check the speaker wires for shorts. Or disconnect the speakers and pray it comes back to life, then isolate the shorted (dead) speaker.
Feb 23, 2010 | Yamaha RX-V657 Receiver
Looking to buy another Clairion Convection Heater - HC-1500 here in Florida 34429 whats the closetes store location or web site to buy one
Where in the Toronto,Ontario area or N.Falls/Buffalo NY can I purchase the HC-1500 Clairion Convection Heater?
Thankyou in advance for your attention.
M.A.Mike
Dec 18, 2009 | Clairion Convection Heater - HC-1500
At mid to high rpms the accel shuts off and car slows
change the fuel filter first then if that dont fix it then it's the fuel pump breaking down
Aug 19, 2009 | 1997 Honda Accord
Amp turns off
You did not specify the model you have - however the Flex series is only stable with a load of 4 ohm mono (bridged) and 2 ohm (stereo).
You are driving the amplifier to work too hard, and it is shutting itself down.
Re-wire using one subwoofer (bridged) or wiring the subwoofers on seperate channels.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | Car Audio & Video
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
Amp cuts out and back on 30 or so seconds!! Volume has no impact
You need to check the B+ and remote voltage on the amp when it cuts off (assuming that you can recreate the fault).
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
Nov 29, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Clarion CZ501 Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
