Copiadora canon ir 6570 codigos de error
EL COMPAGINADOR ESTA TRABADO Y NO SE MUEVE NO PUEDO COMPAGINAR
eagle338
  • 4889 Answers
SOURCE: error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s)
according to the function listed in the table below.
(Each time the Stop/Reset button is pressed,
the LED lights alternately in orange and green, starting with orange.)
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Posted on Jul 09, 2008
MXM450
  • 62 Answers
SOURCE: como configuro la copiadora impresora canon ir 1023
tiene que ser una 1023 con habilidad para imprimir. aunque no lo creas no todas las 1023 imprimen. si la tuya si imprime no debes tener mayor problema al conectarla via usb debe detectarla windows y se instala como una impresora cualquiera. ojo, el hecho que tenga puerto usb no quiere decir que sea impresora.
Posted on Jan 22, 2009
SOURCE: Error de sistema
tengo una fotocopiadora canon 1670 y me dice error del sistema e000 nesecito saber que sera por favor
Posted on Jun 03, 2010
SOURCE: manual de partes de la copiadora toshiba e-studio 35
visita esta pagina www.gioffice/op_manual tal vez les ayude en algo, yo busco el manual dee partes de Toshiba e282, si alguien lo tiene se lo encargo... mi direccion dianali96arrobahotmail.com saludos y gracias
Posted on Jun 29, 2010
muntejaya
  • 10421 Answers
SOURCE: no puedo instalar mi copiadora
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay malzr
Posted on Feb 12, 2011
Compre una tarjeta y cuando entre el codigo en mi computadora para comprar games el sistema me dice que el codigo esta mal o que la tarjeta no tiene fondo que puedo hacer
Primero identifica que estas entrando el codigo correcto. Tratalo por lo menos dos veces. No trates esto mas de 10 veces porque subes el riesgo donde PSN puede cerrar tu codigo.
Si eso no funciona, asegurate que el codigo que te dieron esta activado. Para asegurarte de esto, verifica en tu recibo de la tienda que te activaron tu codigo al momento de comprarlo. Normalmente en el recibo de la tiendo debe de decir ACTIVAT FEE.
Otra opcion podria ser de simplemente esperar. Puede ser que tu codigo se cerro si lo intentaste muchas veces. Solo espera unas horas para entrarlo otra ves.
Tu ultima opcion podria ser de solamente regresar la tarjeta a la tienda a cambio de una nueva.
Gracias.
Feb 27, 2011 | Video Game Consoles & Games
Codico do controle de tv panasonic
Hola mi nombre es Kimberly Escobar con DISH Network. Tengo entendido que necesita los codigos para programar su T.V Panasonic a su control de DISH Network, con mucho gusto le puedo proveer esta informacion. Ciertos codigos que se pueden integrar al control serian los siguientes: 685, 512, 734, y el 700. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba del control hasta que los demas botones se enciendan en rojo una vez esto suceda ingrese uno de sus codigos seguido por el signo de numero por ejemplo 685#, el boton de T.V debe de iluminarce 3 veces despues de esto puede tratar de usar su control con la T.V y deberia funcionar. Si tiene cualquier pregunta me puede contactar directamente a kimberly.escobar@dishnetwork.com tambien puede visitar nuestra pagina oficial http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos y ayuda en como resolver problemas con su equipo de DISH Network. Gracias y espero que esto le sirva de ayuda.
Feb 19, 2011 | DISH Network IR Remote Control
Mi copiadora IR 5020 se para y arroja cod E 0000020 y manda a apagar y encender el equipo que es este error
check the toner hopper maybe the toner is empty or the hopper motor is failed to fuction
Dec 03, 2010 | Canon imageRUNNER 5020 Copier
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
QUE TAL SOY CLAUDIO BERTON DE MENDOZA ARGENTINA, I MAIL claudio.ugarcop@speedy.com, SE DESCONFIGURO EL CODIGO DE ENCENDIDO DE LA LLAVE Y NO CONTAMOS CON EL CODIGO MAESTRO, NI OTRA LLAVE DE EMERGENCIA de...
Saludos Claudio:
Sugiero visitar al representante de la marca; esta es muy especifica y no existe informacion de referencia en el Web acerca de este tema. Lo siento.
Iveco Assistance Non Stop ofrece tanto la asistencia en ruta como el traslado del vehiculo hasta el concesionario mas cerca.
Con solo realizar una llamada telefónica 0800-44- IVECO o 0800-44-48326 , profesionales calificados asisten al instante el vehiculo.
Además si el vehiculo esta en garantía el servicio es completamente
gratuito y con prioridad de reparación en el momento del Service.
Suerte.
Mar 09, 2010 | 2000 Chevrolet Tracker
Codigo de seguridad para ingreso y su funcion
puedo desbloquear una radio kdc-mp522 sin el control remoto
Jul 25, 2008 | Kenwood Sirius KDC-MP522 CD Player
k24674
jasbo
jasbo
