Question about De Dietrich Microwave Ovens
DIETRICH MICROWAVE OVEN DOOR DME799X CANNOT BE OPENED
MicrowaveSvc
  • 9047 Answers
SOURCE: the door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven comes on when
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can order Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 19, 2008
SOURCE: Internal fan on microwave runs with door open
I have the same problem with mine!!
Posted on Apr 11, 2009
  • 167 Answers
SOURCE: I have a GE JE1540 Microwave Oven and worked good
In the cases I've seen, the fan starts operating and sounds like the oven is cooking. This is usually caused by one or more of the interlock switches being out of adjustment.
Posted on Jun 20, 2010
Our De Dietrich DME715X microwave oven is sparking from the ceiling - have tried a new wave guide cover but that did not work.
Some ovens have a tuning stub in the wave guide. If it has become loose or rusted, it could cause the problem. If that's the cause, you would have to transfer all of the oven's components to a new cavity. This is usually not done due to the cost, although I did do this once on an oven that was still under warranty.
Make sure the wave guide is clean inside.
Also check for rust near the wave guide cover. Re painting damaged areas might help.
Sparks fly, too, if the ovens contents do not contain enough water to absorb enough of the microwave energy. Leftover energy converts itself into electrical current in any conductive material (such as cavity panels).
Nov 25, 2016 | De Dietrich Microwave Ovens
Microwave "popped" during use
Could be an open internal fuse
Sep 07, 2016 | De Dietrich Microwave Ovens
My De Dietrich DME 101XE1/3 microwave oven does not work.
I'd check the door switches first. The primary and secondary ones must go into the closed position when the door is shut.
You might also have an open thermal cut out on the outside of the cavity. There is also one on the magnetron you could check, although it's les likely to cause this problem.
Avoid all high voltage components, as there's likely to be a 4000 volt charge on the high voltage capacitor. Unpleasant to touch, and it could be fatal.
May 12, 2016 | De Dietrich Microwave Ovens
How to reset De Dietrich oven DO410
follow this step and fix it. A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
God bless you
Jul 20, 2013 | De Dietrich Microwave Ovens
Tried to change time on clock and all the power has gone out of the microwave
The fuse in the microwave has blown, there are any number of reasons for this, one of the door switches has failed, "common problem" or in some cases just the fuse will go.
Mar 25, 2012 | De Dietrich DME101 1000 Watts Convection /...
The turn table doesn't always rotate. If you move it manually it will sometimes work for a short while.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 04, 2011 | De Dietrich MM6768 900 Watts Convection /...
Sometimes heat food and then not
Basic
heatman101
Jan 11, 2011 | De Dietrich DME112X Microwave Oven
Microwave has power but start button not working
Usually a shorted high voltage capacitor...see components section
Sep 17, 2009 | De Dietrich DME112X Microwave Oven
De Dietrich DME 112 XU2 Turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Dec 13, 2008 | De Dietrich DME112X Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tom Chichester
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
