Question about Zebra GK420D Direct Thermal Label Printer
Change serial communication parameters like baud rate
I can not change the baud rate of a GK420d. I tried the autobaud, ^SC command but I can connect to this printer only with a baud rate of 9600 (default.)
3 Suggested Answers
  • 62 Answers
SOURCE: how do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Posted on Apr 18, 2009
  • 54 Answers
SOURCE: We have a Zebra GK420d
You can enter the internal web page and set the printer from there. Or from the printer driver, you can set the darkness and speed there.
Or in your label printer software.
Posted on Jan 11, 2011
Baud rate hp 9600
why need to change baud rate, no need to change???
because it is not a serial port printing it is usb port printing....?
Oct 01, 2013 | HEWLETT-PACKARD LaserJet M1522nf...
PP8000B printer just prints garbage..and Cash drawer doesn't open have tried the O POS manager , tried almost everything .. Any suggestions welcome...HELP
Every POS software has commands that opens the cash drawer and prints the ticket. It also controls how long the receipt ticket is, if it prints in color. Then there are two types of cables that communicate between the cash drawer and the printer to pop the drawer. Then there are dip switches in the printer that change how the printer operates according to the software. When it prints garbage, the driver that comes from the POS software is not synced with the printer. Sorry you asked. Call the POS Software company.
Apr 10, 2011 | Posiflex PP7000 Printer
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
How can I change the baud rate on my HP Laserjet 3380?
There is no baud rate to this printer, it's either parallel cable or USB cable. Baud rate refers to the old serial cable connections, com1 or com2. You can add memory to this printer to make it print more documents faster. Try this location:
http://reviews.cnet.com/multifunction-devices/hp-laserjet-3380-all/4505-3181_7-30822993.html
May 11, 2010 | HP LaserJet 3380 All-In-One Printer
My system tell me that my serial port is running at 9600 bad. My motherboard is new enough to be running at top speed. What is the problem and is there anything I can do to fix this?
The mother board can be new enough to run at 19200 Baud rate or even more but most of the devices run at a baud rate of 9600. If the baud rate of the motherboard is increased then the communication between the device and the motherboard can become an issue.
If you still want to change the baud rate then the option will be available with the software you get with the device you are using with the serial port.
If I can know the device attached to the serial port then I can help you further.
Kindly Comment.
Jul 23, 2009 | Office Equipment & Supplies
4800 baud rate communication in vb
You have to change it on both side!
If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
But you can change it depending on the device...
Jan 03, 2009 | Computers & Internet
Slow Printing
is it serial or parallel?
If it's serial, You can change the com port settings (baud rate) to a higher speed. You would need to change the dips on the printer to read the same Baud rate.
Mar 25, 2008 | Citizen CBM 1000 thermal Printer
Change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Zebra GK420D Direct Thermal Label Printer Logo
    143 people viewed this question
    Top Zebra Office Equipment & Supplies Experts
    Dave Busselle
    Level 1 Expert
    Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
