Television Codes Murphy 32883 IDTV code065 will not work my volume on my skyhd
My code to connect to my Sky HD is 065, however this will not work
  • 905 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
SOURCE: Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
Posted on Jun 14, 2009
  • 325 Answers
SOURCE: Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Posted on Sep 01, 2009
welsh babe
SOURCE: REMOTE CODE FOR SKY REMOTE FOR BUSH A642F LCD
the code is 253
Posted on Apr 17, 2010
SOURCE: Just purchased a Toshiba 32BV700B
try 1191
Posted on Sep 29, 2010
I have a TV (Murphy 22883 idtv hd dvd) and no idea how to use component
I suggest you study the operation manuals and follow step by step.
Aug 13, 2012 | Toshiba REGZA 47HL167 TV
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Looking for code for sky remote for television
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre/producthelp
also check the below link -
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
Jun 14, 2010 | Televison & Video
What is the sky remote code?
These codes are for Samsung, one of them will work: 065, 584, 037, 245, 476, 398, 516, 292, 318, 037
Hope this helps
Mar 22, 2010 | Samsung SyncMaster 151MP 15 in. LCD...
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
Goodmans LD3266D TV - need the code to work volume control on my sky HD+ revision 8 remote control
Well first you can try - 065, 064, 100, 285, 037, 292, 544, 207, 318, 363, 399, 402, 515
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
http://www.skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
Mar 13, 2010 | Goodmans W280NS Television
Remote control code
Television Direct Codes for Sky remote:
Goldstar 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
Here are the codes for GoldStar which became LG. They might be the same.
Good luck,
Techjoel
May 09, 2009 | LG Televison & Video
Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
Dec 29, 2008 | Televison & Video
Sky+ remote codes
hi
i have here some writeups i found during surfing for your sky remote.
Not every TV is included in the code list. In fact, although it was claimed that "95 percent" of TVs could be controlled by the Digibox remote, the true figure is probably "95 percent of last year's models" and the standard remote will NOT control your Video Recorder or any other equipment.
UPDATE October 31, 2006. The latest versions of the remotes are SKY Rev.8 and SKY+ remote are Rev.6 and Sky-HD are Rev.8 (Sky-HD also operates the SKY+ Digibox and contains codes for more recent Plasma and TFT screens). Look at label inside the battery compartment. These remotes contain codes for more recent TV sets and omit codes for TV sets that are now several years old. We do not stock earlier revisions.
seems here that they may have no codes for your tv.
i will just update you if ever i find codes and ill post it here.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
