Question about Behringer Xenyx X1222usb X1222 Usb X 1222 Usb Audio Mixer
2-Track/USB Input Output Doesn't Work
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
Apr 29, 2011 | Computers & Internet
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
NO SOUND ON PLAY-BACK
I had a similar problem but I just plugged in some heaphones into the mic and I got everything in the DAW to play back through them.
May 18, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Troubleshoot
The mic is on the left side. That's how it's supposed to work. You should set your recording software to only record the left channel on one track and the right channel on another track.
The level controls are the knobs on the front.
Apr 07, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Behringer Xenyx X1222usb X1222 Usb X 1222 Usb Audio Mixer Logo
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
