Question about Car Audio & Video
MTX Thunder 2300 Amp Service Manual
I recently experienced problems with my amp. The LED no longer lights and there is no sound, although at one point it sent a "pop" through the woofers then worked until I raised the volume to a higher level (loading the amp). It then shut off and hasn't worked again since. I have checked the system for power and there is power to the amp. I was hoping that I could get my hands on the MTX service manual so that I could troubleshoot it myself. When I asked MTX, they weren't willing to share the manual, but offered to identify values of "bad components." I thought that would be difficult to determine unless there was physical damage to something. At this point, I haven't cracked the amp open yet. Any help would be great! Thanks...
techman
  • 3130 Answers
SOURCE: Keep poping the 40 amp fuse on the amps itself when the volume is up at all it seems
Your units drawing too much current. it could be a wireing problem, a speaker problem, or the amp has a problem. the correct way to troubleshoot this would first do or have the amp bench tested. Or you can remove all the speakers and wires and turn up the amp. If the fuse still pops,have the amp serviced. Good Luck
Posted on Aug 16, 2006
SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Posted on Oct 03, 2007
  • 86 Answers
SOURCE: Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
Posted on Feb 12, 2008
  • 631 Answers
SOURCE: mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Posted on Aug 19, 2008
  • 631 Answers
SOURCE: MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Posted on Sep 29, 2008
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Mtx 1000xd led light is flashing and the subs will not work
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
Sep 19, 2009 | MTX X Thunder 1000XD Car Amp
MTX thunder 304 4ch red amp light comes on but no audio have triple checked all connections and they seem alright
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Jun 09, 2009 | Car Audio & Video
Sep 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
My amp doesn't turn on...
If there is a zero ohm connection across the B+ and ground terminals, it should blow the fuse as soon as you apply power.
Oct 10, 2007 | MTX Thunder TA7801 Car Audio Amplifier
Sond gone
sounds like an internal problem. first disconnect all spks from amp, then switch on head unit and check if amp turns on (LED ON?) then feel the heatsink, if heatsink gets terribly hot then amp has internal fault. if amp doesnt get hot then try connecting a single working speaker to each channel separately, it may occur that one channel is faulty only. amps can shut down if the speaker/s is faulty as well, check all speakers and spk wires for shorts before taking amp in for repair. cheers
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
Delay
10 to 20 minutes? that sounds like a internal problem in the amp. I have never heard of a amp taking that long to start up, there is definatly a problem in the pre amp stage of the amplifier.
Mar 01, 2007 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
1,128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
