Question about Microwave Ovens
Sanyo Microwave Ovens EM-X461-W NOT FUNCTIONING
I KEPT BREAD IN MY OVEN AND AFTER SOME TIME IT GOT BURN AND OVEN STOP WORKING
SOURCE: MICROWAVE OVEN
TURN TABLE WORK S BUT THE GRILL IS WARP
Posted on Mar 31, 2008
SOURCE: Service manual of microwave SANYO EM-D953
hi
If you are still looking here is tthe link for the instruction manual for that model which is the same one i have used for years
http://www.sanyo.co.uk/download/1659661.pdf
Have fun
Posted on Jul 04, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
SOURCE: REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Posted on Apr 11, 2009
  • 60 Answers
SOURCE: need a user manual for a Sanyo Convection and grill model em-d981
Need one too - if anyone has one that is in .pdf format they could send it would be much apreciated
Posted on Jun 09, 2010
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How do i fix a sanyo microwave
call ser. tch. ur motor might be spoiled already . its a added function mabe of the unit if ur turntable motor not wroking so does ur microwave
Feb 21, 2015 | Sanyo Microwave Ovens
Paper bag and food burned in the micro...it now smells with each use
Mix plain bleach in water and clean interior until spotless, the process may need to be repeated 3 or 4 times to diffuse the smell.
May 03, 2012 | Microwave Ovens
The microwave stopped suddenly - they put in a new fuse and it kept blowing the fuse before a determination could be made as to the reason why it stopped working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 14, 2011 | Samsung Microwave Ovens
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
Keypad does not work after steam hits it
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Keypad failure can cause it to come on by itself, which can lead to a fire.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 24, 2010 | General Electric Microwave Oven
Built in Microwave won't turn off!
Your machine is probably burned up by now ... but I will try to help you.
I suspect your door safety interlock switches are selded in the closed position. Remove the cover and look on the right hand side for these small switches. Unplug the device and be mindful there is 25,000 or more volts waiting to get you in the silver thing to the back side. Check the switches with a ohm meter. There is a common terminal, a normally open terminal and a normally closed terminal. My guess is one or both switches are going to read closed (short)
Sep 07, 2009 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
