Question about HEWLETT-PACKARD PW550 Digital Camera
HP PW550 Digital camera when take A picture the images has lines when it shot on bright place
Why are there lines in my photos
The manual says:
This phenomenon is called smearing. This is not a malfunction. Smearing is not recorded on still images, but is recorded as streaks or uneven colors on Sweep Panorama images or movies. ("Bright areas" refers to the sun or electric lights which are much brighter than surroundings.) It does not say a thing about lines in the prints. Are you sure the pictures do have lines too? Can you describe this more accurate?
Description online of Sony DSC-H200
Nov 25, 2013 | Sony Cyber-shot DSC-H200 20.1MP Black...
Horizontal lines show up while taking a picture and the brightness is also messed up
You're camera most probably has a CCD (image sensor) problem. This is a widely spread problem common in digital cameras. The CCD is damaged due to a high temperature and humidity giving your shots with horizontal white thin lines. However this problem does not affect when taking videos on your digital camera. Canon has acknowledge this fault and they usually accept the repair for FREE regardless of warranty. Please click the link below to give you a proper documentation about the ccd failure.
http://www.imaging-resource.com/badccds.html
Hope this helps. Thank you for uisng FixYa.
Jan 24, 2011 | Canon PowerShot A470 Digital Camera
Photo shots: the pictures look as if a super flash wash used, even when flash is not used. Movies are o.k.
It is problem of ccd imager chip in DSC-T1 camera that gives you washed out still image after taking shot/ stored image, you may get live view correct in camera mode and movie but it saves taken still picture over bright etc.
Replace ccd imager chip by local camera repair shop to solve this issue.
Thanks.
Nov 16, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cyber-shot DSC-H2 all the photos I take are very bright and when I download to my pc there are horizontal lines on them
The video or images are being recorded too bright or too dark. Solution
sp.gif sp.gif Follow the steps below to troubleshoot if the video or images are being recorded too bright or too dark.
IMPORTANT: If additional information is required to perform any of the steps below, refer to the operating instructions of the camera. The operating instructions are available in the Manuals/Specs/Warranty section of the Sony® eSupport web site.
  1. Remove any accessory lenses that may have been installed on the camera.
  2. Manually adjust the exposure setting of the camera or use a different Program AE mode.
  3. Adjust the white balance of the camera.
  4. Verify that any special picture effect features are turned off.
  5. Take pictures or shoot video in a location with different lighting conditions.
  6. Reset the camera.
If all the pictures and video exhibit the same issue after performing all the troubleshooting steps, service may be required .
Jul 23, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-Shot weird lines, dosent like bright light
It is a bad ccd it need to be replaced some time you can get lucky by resetting the camera in the setup menu.When you take a picture the image is transmitted throught the ccd and translates the image to the cameras memory. It can be fixed. Or you can upgraded. Some places might offer a trade in value on your camera even if it is broke.
Mar 24, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Only see bright light effect in viewfinder and LCD
the Screen has failed or a connector to the main board has come lose. Check out the Makers help line for advice. The likely cost of a repair is going to be high be prepared for a new camera.
Oct 29, 2006 | Konica Minolta DiMAGE Z2 Digital Camera
HEWLETT-PACKARD PW550 Digital Camera Logo
Top HEWLETT-PACKARD Cameras Experts
Are you a HEWLETT-PACKARD Camera Expert? Answer questions, earn points and help others
