Question about Pool & Spa
Porpoise 90/10 pool mump service manual
How to dismantle the water pump
Service light comes on pool shuts down. Everything is clean.
either a filter is blocked a pump isnt moving
check all pumps work
or the water is turned off
you may need to reset any error that has already been detected
try turning its mains off for 1/2hr
look in the user manual
ask the maker by email for the service manual
etc...
Dec 21, 2014 | Pool & Spa
Is there a Porpoise 90/10 pool pump service manual available online
Just check Hoses and dont disassembly nothing.maybe you dont have to do that.Sucking air is because there is a bad gasket assembly,or a broken hose, or pipe.
Aug 15, 2014 | Pool & Spa
Pump wont turn on
make sure heat maintain is off if ok new pump
Apr 04, 2014 | Pentair Pool & Spa
Hello I'm trying to dismantle my hayward pump, but can't seem to able to remove the turbine... without forcing it too much....any tricks?
IT TURNS OFF TO THE LEFT, YOU NEED A 7/16 OR A 11 mm WRENCH TO HOLD THE ROTOR AT THE BACK OF THE MOTOR.. LOOK FOR THE NOTCH IN THE SHAFT UNDER THE SYNTRIFICAL SWITCH ASSEMBLY , BE CAREFUL NOT TO BREAK ANYTHING ON THE BACK OF THE MOTOR. REPLACE THE SEAL ! THERE IS A GUY SELLING SHAFT SEAL HAYWARD SUPER PUMP MOTOR REPAIR KIT & how to
ON EBAY .. HEY YOU .. PRIME THAT PUMP AFTYER ANY PUMP REPAIR !! THERE NOT SELF PRIMING UNTIL THERE INITIALLY PRIMED IN FIRST PLACE !!! AKA PUT WATER IN THE PUMP !.. IF I WAS OF HELP CLICK ON THAT (YES) BUTTON ON THE BOTTOM LEFT OF THE PAGE.. REMEMBER A CLEAN POOL IS A SAFER POOL .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA ..
Jun 11, 2011 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
My pool pump has stopped working. It reads "service". It was cleaned but still not working
As stated in the manual the actual service indication is an Intex situation no matter what. There is no resetting when this light comes on.
Give them a call. If you have a valid receipt and it is under 2 years old Intex will send out a new one.
Jul 01, 2010 | Intex Automatic Salt Water System for ...
My sister lost the manual. where can i get another?
The full range of manuals is available on the Intex site, see http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2010&source=intexstore&gid=2&lid=12125 for salt water system manuals (and access to other manuals for Intex products, for example pools, filters, boats, etc.)
May 31, 2010 | Intex Automatic Salt Water System for ...
I have a Pentair whisperflow pump/motor and I keep losing water from my pool when the system comes on. It seems to like **** a bunch of water out. I had pool company to come service and clean system, but...
If you don't see any leaks check your Backwash. If it has any water coming out of it you have a problem with the valve. Hope this helps but I can't say more without inspecting the system. You may need another pool service look for the problem but check the B/W first.
Feb 22, 2010 | Pentair 1hp Whisperflo Pool Pump In -...
I have an Intex 15' x 42" Easy Set pool. I bought chlorine tablets for it, and thought I could put them into the skimmer basket. Now I'm not so sure, and I can't get the DVD to play, and I've lost the...
Buy an inexpensive floater for in the water and put them in there. Putting them in the skimmer will just shorten the life of a pump that will already struggle to give you 3 years of service.
Jul 31, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Pool & Spa Logo
113 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
