Question about Epson Stylus C84 InkJet Printer
The ink i replaced the black ink and now the printer does not print. it was printing fine before. all the other inks are up to date.
  • 3 more comments
  • leanie Dec 06, 2007
    The ink was running low on my Epson Stylus C84 so i changed all 4 cartridges and straight away it is printing blank pages, i put the old cartridges back in and still blank. The printer goes throught the process of printing but still blank. I followed the instructions to clean the heads and still blank, even the test sheet to see if the heads needed cleaning, blank, obviously.....
  • kenoward Dec 09, 2007
    I have the same experience I replaced all of the cartiridges, but only have blank pages...Help
  • Anonymous Jan 06, 2008
    I just put two brand new ink cartridges in and when I print the paper comes out blank.
  • angela3 Feb 22, 2008
    I just brought a new set of cartridges and replaced only the black. However, the printer will not print. It said something about cleaning the print head. How do I do it?
  • carla susana Mar 10, 2008
    i replaced all 4 cartrages but only the black and blue come out,the yellow and the magenta are not working . i have cleaned the head but nothing gets better, what should i do?
    carla
    Sergeant:
  • 390 Answers
Yep, thats printers for you!!! It is one of a few things, but we will narrow them down. First, when you replaced it is it in best correct position and not sitting up, some people accidenatlly fail to push it properly home and this reslts in no printing. If it is ok, is the colour ink printing ok. Post back as this helps identify issues.
Posted on Sep 01, 2007
Replace the printer cartridge or clean cartridge head using clean mode .you may also need to replace the cradle to inkjet site on in some models(canon BIC for example)
Canon mg5200 only prints photos
I have an MP540 and it says..."The PIXMA MP540 runs on five ink cartridges, with a photo black as well as a pigmented black for text printing" so it sounds like pigmented is for text and dye for pics. So maybe your default settings are showing high quality, photo or the paper type is causing the printer to select high quality...just a thought!
Parts Of BMW.
May 30, 2012 | Canon Large Black Pixma Mg 5200 Compatible...
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
How to use ink I have purchased?
i don't know what printer do you have, but HP print cartridges are resetable, just find it on google, type your printer type and reset cartridge
Jul 10, 2009 | HP Office Equipment & Supplies
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Wont print black because it doesnt have color ink
So for now, you can change the print settings to only print in black.
Change the print properties/ colour to grayscale.
May 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Canon Printer won't print black ink.
Hi , printer need head cleaning until the black ink visible and dark black appear. Replace also the retaining tank with absorbent pudding.
Apr 01, 2008 | Canon i455 InkJet Photo Printer
Epson Stylus C84 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
