Question about Cub Cadet Riding Lawn Garden Zero Turn Tractor
Rzt50 22kawasaki runs rough sounds like it bogs down when you engage the blades
The motor bogs down when the blades are engaged and the deck is clean. Any suggestions?
Sounds like you need to lubriate the swindles that rotate the blades are the belts tension are ok
Aug 20, 2015 | Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Why does my 60" Xmark Lazerz Ultracut bog down and kill the engine?
I suppose it's possible but, without belts on then i don't think it would do that. It sounds like maybe the safety switch isn't working right. Could have a loose wire, broken wire or bad switch. When you go to engage if the safety switch isn't working right it will kill the motor
Apr 22, 2015 | Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Bogs when blade is engaged
for this to happen you must have a bearing problem either in the gear box or cutter deck that has seized from rust or failed bearings. disconnect the cutter belts and see it t moves forward freely If so then turn each cutter spindle by hand and find which one won't turn or is rough in the movement.
Jun 09, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 | Toro Garden
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
Scotts mower kohler command 25 motor bogs when mowing
Hi..my name is Keith..and it sounds like you have a binding somewhere on your mowing deck..i would check all the spindles .. pulleys and blades..and check the deck belt..it could have jumped a belt guard and it running on the outside of it..but just remember it has pulley brakes to slow the pulleys down when you shut it off..so..engage the deck without the engine running and check for the binding..i hope this has helped..if not..please write me back
Jul 14, 2009 | Garden
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
The engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
May 23, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Cub Cadet Riding Lawn Garden Zero Turn Tractor Logo
37 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
