Question about Solis Crema SL-90 Espresso Machine
Brew head gasket - Solis Crema SL-90 Espresso Machine
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Barista Athena Brew Head leaks water
Try adjusting the grind.
Posted on Mar 07, 2010
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Fetco cbs 51h drips water
Replace the brew solenoid on top of the sprayhead. Either something is keeping the spring and gasket open or the gasket is damaged. Get a rebuild kit from fetco or a new brew solenoid.
Oct 02, 2013 | Fetco International Coffee Makers &...
My portafilter is leaking during brewing. seems it can not get as tight as it previously was able too. I have the model with the 3 settings and even on Ristretto, the coffee comes out way too fast and the...
You need a new brew head gasket. They are not that hard to change. Four nuts hold the chrome head on. Once the chrome head is removed the gasket is pulled off then the brew head is cleaned and then you can put the new gasket on. Check ebay.
Feb 06, 2011 | FrancisFrancis! X1 Espresso Machine
The handle is coming apart. It does not fit tight enough & sometimes falls while the coffee is brewing. Where can I purchase a new one to fit my Solis SL 70 machine purchased late in 2004.
HI
If the portafilter is coming out when brewing your brew head gasket needs to be replaced. If you have never replaced your brew head gasket its way beyond time. They should last about 3-4 years at the most. With a good brew head gasket the portafilter should be easy to lock in, not requireing a lot of pressure to force it over. Try replaceing the gasket first before you invest in a new portafilter. If you really need one I have some and the gaskets.
Jan 31, 2011 | Solis Portafilter for SL Series - 521.05
When brewing with the X1, water starts leaking from the underside of the top where the brass filter holder connects to the machine. Tightening the 4 nuts did not help.
HI
More than likley its your brew head gasket that is leaking. Take off the 4 nuts you hust tighten and it exposes the brew head gasket. Make sure that you put the chrome piece on the same way you took it off. Clean the head good before you put the new gasket on or you could have trouble.
I would check ebay.
Jan 31, 2011 | FrancisFrancis! X1 - Stainless Steel...
How do I remove the shower and the diffuser on an isomac millenium?
Hi
You need to remove the brew head gasket in order to get the screen out. Then you will see everything else. The brew head gasket holds everything in.
Jan 16, 2011 | Isomac Millenium Espresso Machine
I own a Breville 800ESXLespresso machine which i already decalcified, that leaks from brew head and handle moves while brewing
If you've had the machine for a while, your brew head seal (gasket) is probably damaged or shrunken from age/heat and needs to be replaced. That's most likely why the filter holder moves and leaks while brewing. Breville brew head seals are rather difficult to locate, but I personally stock them and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Nov 27, 2010 | Breville ESP8XL Espresso Machine
Brew head leaks at gasket,causing some water to bypass the coffee and leak around outside of brew head
The filter holder not pushed far enough ino lock position, also the basket doesn't quite hold 2 level spoons of coffee.
Thanks, David
Jun 18, 2009 | Briel Chamonix ES-35 Espresso Machine
Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
Mar 02, 2008 | Solis Crema SL-90 Espresso Machine
Solis Crema SL-90 Espresso Machine Logo
27 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
