Kenmore washer 110 21102011
I have a kenmore top load washer 110.21102011. The water dribbles in during the fill cycle. Have checked both the hoses and the screen filter where the hoses attach to the washer..both are clear and the water flow is fine. After a few minutes in the fill cycle (nowhere near filled) the washer drains the water. When it starts to drain all lights are go off except the lid lock which remains on. Once the water has drained the wash light goes on but the lid lock light goes off and the lid unlocks. The wash light remains on but then nothing happened.
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
aborcass
  • 2651 Answers
SOURCE: kenmore elite h4 washer fh code
F/H is a no water fault code, so i would recheck your incoming water supply, or look to a problem with the inlet water valve.. if your using stainless steel hoses, form the manufacture lableld FLOOD SAFE, these maybe your issue as well they have a buitl in water shut off, htat may be failing preventing water from entering
Posted on Nov 30, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
  • 51 Answers
SOURCE: Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
Water is leaking onto floor during filling and also during the rinse cycle.
you will have to check the hoses coming from the water inlet solinoids as it sounds as if there is a leak in one of them.
Jul 27, 2011 | Kenmore 23822 Top Load Washer
Washer is working during spin, meaning it's still
Hi, a Kenmore washer that is not filling with water may have clogged inlet screens. Place a bucket underneath the hoses to catch any leftover water. Unplug the washer and turn off the water supply. Remove the water hoses from the back of the washer and inspect the screens inside the inlet ports. Often, these clog with sediment. Clean the screens with a small toothbrush. After cleaning, reattach the hoses and turn the water supply and power back on.
Another reason the washer might not fill is something interfering with the water pump. Check the connecting hoses on the water pump to make sure they are not clogged. With the hoses disconnected, check the water pump for obstructions.
Jun 19, 2011 | Kenmore 24722 Top Load Washer
Kenmore washer only fills on the warm water temp control and dribble fills on with the other choices. When it goes to rinse, it dribbles on all temperatures. Have resorted to fill by hand. No problem...
As you have already checked the hoses are not kinked and the in-line filters are clean, this is symptomatic of a malfunctioning cold water control valve. Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 09, 2011 | Kenmore 15864/15862 Top Load Washer
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine is leaking water from somewhere?
there is a seal between the drum and transmission,more than likely thats where its leaking. also check your fill hoses and valve
Jan 09, 2010 | Kenmore 22422 Top Load Washer
Cold water dribbles in rinse cycle, hot and warm water fine
If you check the warm water flow you'll likely find it is HOT...and not warm. Check the faucet end of hose to see if screen is clogged. Should be screened washer with the dome portion of the screen facing out at you. Remove it and clean with brush to remove grit or scale from screen. If you find nothing there you need to replace the water fill valve located at the other end of the hoses. Good Luck
Aug 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 90 Series fills so slow on rinse cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
