Question about HP Color LaserJet 4650DTN Printer
Changing Roller/Seperation Pad in Tray 2
Does anyone know how to get to the existing roller and seperation pad in tray 2. They need replacing but I just can't get to them? I can see where they are but can't remove any of the surrounding parts to get to them Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1-Open tray
2-lift left side of roller ( it is spring loaded and should lift easily)
3-pinch rollers and remove
4- take out whole tray and look inside underneath to see pick-up and feed rollers.
Posted on Oct 19, 2007
SOURCE:
After refilling the printer is not printing more than one page at a time
the paper feed rollers/ seperation rollersare the most likely cause- the machine will make three attempts at feeding from the cassette before throwing a jam light . open the paper tray and completely removethe feed tray which then gives you clear access to the feed roller ( black about 1 1/2" long) positioned about 2" into the cavity on the top.#
clean this roller (slowly turn roller to get at all sides) with wd40 Spray (on cloth) allow 5 mins for the cleaning fluids to do their job and then completlely wipe off any oil from the roller - given another ten ,minute to air the feed roller should now work again at least for a little bit - You can order a maintenance kit which contains this roller and also the seperation pad ( found on the cassette ) as well as a new fixing unit .which will most likely fix the fault good luck
Jan 29, 2014 | HP LaserJet 2420dn Printer
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
The paper feed takes more than 1 page at a time and keeps jamming up the printer. How do I fix the paper feed?
take out the paper tray. On the tray you will see a roller and/or seperation pad. Clean it with a damp cloth with a dab of dish detergent. Then look in the cavity where the paper tray slides in. there you will see another roller. clean that one too.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 21, 2011 | Brother HL-2040 Laser Printer
Roller not grabbing the paper
On the paper tray, rub clean the seperation pad with a damp cloth. Then look under the unit where the tray is inserted, there is a roller, clean that too.
Dec 06, 2010 | Samsung SCX-4725 Laser Printer
How do you replace a pick up roller on a brother HL 2040. I bought the part.
The pick up roller is in the paper tray. It is the roller in the middle front of the tray. Usually, you press the roller to one side and it will pop out. Install the new one doing the reverse. There is a seperation pad that may need cleaning, too. Rub it with a damp cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2010 | Brother HL-2040 Laser Printer
The manual feed tray taking more than one page, sometime three or four pages at a time print on one page only.
The seperation pad is worn out. order a seperation pad and tray 1 feed roller. you can usually pop out the seperation pad with a small flathead screwdriver and the new can be clicked in its place. the feed roller has a blue tab that unlocks it from the axle.
Sep 08, 2010 | HP LaserJet 4050tn Printer
I have the same problem; every 2nd page is blank
sounds like the seperation roller in the paper tray is worn .. this roller is there to stop multiple feeds or it may have a pad in your tray open the paper tray up and look at the roller in the tray or the pad ; and give it a clean with a damp cloth.. also check the paper if it has been in the tray over the weekend when not used sometimes they pick up cold or dampness and so the paper sticks to the top sheet.. Im thinking more on the lines of the sepertion roller/pad area.. Goood luck A
Jul 20, 2009 | Sharp UX P200 Plain Paper Thermal transfer...
Printer will jam on mulitiple page print jobs gets a 13.1 error all rollers have been changed, jams just after the letter tray and only jams from legal tray 3 ???????
OK you said you replaced the rollers. If you have not repalced the SEPERATION PAD, (located directly under your pick up roller....thats your problem. Easily done.
Mar 12, 2009 | HP LaserJet 4650 Color Printer
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
Why is the printer grabbing more than one sheet at a time?
this is caused due to the pickup rollers and seperation pads being worn. if you run your fingers across them you will no dobt find that they are very smooth and thats the problem. the rollers and pads need to be rough so that they can cause friction against eachother to seperate the pages. i
What make model is it and i will try source the part numbers for you
Hope this helps
Pete
[email protected]
Oct 03, 2007 | Lexmark T632 Laser Printer
HP Color LaserJet 4650DTN Printer Logo
76 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
