Question about Coffee Makers & Espresso Machines
Wiring diagram heat element - Coffee Makers & Espresso Machines
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Coffee Maker... Master
  • 102,366 Answers
What make and model coffeemaker?
Posted on Jul 28, 2013
Need diagram for wires that hook up to heating element on fridgeidaire model LAQE 7011KWO Dryer
Hello. There are black and yellow wires that connect to the heating element. The black comes from the inlet thermal limiter fuse, the yellow comes from the main drive motor. There is always 120 volts at the element. When the dryer is initiated, the motor, using a centrifugal switch, connects another 120v supply across the other side of the element which totals 240 volts and causes the element to heat. This is done intentionally as a safety feature--the element can't heat if the motor isn't running.
Aug 18, 2015 | Frigidaire Dryers
Tip
Electric Water Heater Wiring Diagram
If you are changing a water heater thermostat on your hot water heater, or would just like to troubleshoot your hot water heater, you may want to know how it is to be wired.
Here is a diagram of the way a normal electric hot water heater with two elements that run non-simultaneous will be wired. This means that only one element at a time will be working and have power going to it. The top element will heat water until it is heated to your set point and then it will switch the power to the lower element to heat the bottom of the tank. This gives you some hot water quickly, and then heats the rest of the tank.
For more information on how to troubleshoot electric hot water heaters you can check out this tip.
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
on Mar 27, 2010 | Heating & Cooling
Need to hook up wire for the element in the kettle of my GR6A1X -XX -X
Here is the wiring diagram for that model. Black(hot) wire to empty side of thermostat, red(indicator lamp) wire is doubled to the wire that goes to heat element, and the white wire is attached to far end of heat element.
Dec 13, 2012 | Cretors Goldrush Popcorn Maker
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
We replaced the heating element, but don't know which wires go where to reconnect
Should be color coded Reds and black wires are hot greens are ground writes are nutural. Google your heating element wireing diagram
Sep 05, 2010 | Kenmore 62622 Electric Dryer
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
I just replaced part number 61927
on most dryers ive worked on, follow wire from element, right before that is a senser..prob bad...PS also two wires to element..does not matter which is which
Mar 13, 2009 | Dryers
The wires on my heating element might be switched any clue on the wiring diagram Changed heating element, it was broke . After about two months a wire going from a sensor to heating element burnt and it...
the 2 wires that go to the element are largest. Does not matter which one goes where. The other 2 wires are smaller and imposible to get on the wrong terminal.
Dec 31, 2008 | Dryers
Test bosch heating element
remove the kick plate at bottom of dishwasher, at the left leg there will be a wiring diagram. remove console and test element from there. diagram will show which wires to test
Nov 16, 2007 | Dishwashers
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
