Question about GE Nautilus 24" Built-in Dishwasher
Should my dishwasher drain completely after its done washing
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Yes it should if it doesn't make sure the dishwasher is sitting level if not adjust the little legs under it to make it level
Posted on Mar 28, 2014
The wash cycle is finished but the bottom of the dishwasher is still filled with wash water how do I get it to completely drain
Still filled is not good.. The process you need to complete is get a wet and dry vacuum and remove the water. A good way to do this is to unhook the drain for the dishwasher from its connection to the house plumbing and put the vacuum on that hose. If you get no water then it is a serious blockage, if you get water it may also remove the blockage by using the vacuum. Then you need to remove the bottom rack and check the sump area for debris and items that may be causing it not to drain. When this is done, run it and see if it drains. If it does not then there may be a pump issue.
Oct 29, 2017 | Dishwashers
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
The water is no draining completely out of the dishwasher, its's a Whirlpool 980 Deries
If you are handy what you will have to do is unclog it. DO NOT USE DRAIN CLEANER. Pull out the filters, clean out the **** and you are good to go. Once you are done with that run it a couple of times and you should be good.
Oct 10, 2012 | Whirlpool Dishwashers
Drain pump goes ON when ON-OFF button is pressed, even if the know selector is in OFF position and the machine is dry. There is no fault codes and the dishwasher complete the washing cycle OK, but when...
Seems that the drain pump circuit in the main program controller unit power and keeps on as there is no logic feedback to cut off the power. It can be that the drain is clogged and so the water level detect keeps sensing due to a fault. check the sensors , check the drain filters , check the machine LEVEL so that the water drains clearly to the drain pump.
Aug 08, 2011 | Miele G7856 24 in Dishwasher
Drainage problem
I had similar problem and rerouted the drain hose like papps54 said. I still had the condition and decided to pull out the drain hose completely to see if there was any debris trapped inside the hose. There was! I removed the hose from the machine completely, cleared out the debris, and let the hose soak in white vinegar overnight. In the meantime, I looked back up the drain outlet and found evidence of debris lodged in there as well. I didn't completely dismantle the dishwasher at this point but I did eventually clear it out as well as the drain filter located inside the dishwasher. After reassembling the drain hose and dishwasher, I cleaned it with baking soda for three nights and now it runs very well with no odors. Runs quieter as well.
Oct 10, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwasher bosch beeping noise
Found this on the Bosch website..... see 2nd to last step
The Cycle Completion Signal
This Cycle Completion Signal is a tone that sounds to alert you when your dishwasher
finishes washing and drying your dishes. You can either disable the tone or set the volume.
To activate:
· P ress and hold the right “Cancel Drain” button then press and hold the On/Off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone
begins to sound, release both buttons.
· P ress the right-most “Cancel Drain” button until the tone is either at the desired volume
or is silent.
· P ress the On/Off Button. The Cycle Completion Signal is now set.
Sep 27, 2008 | Bosch Dishwashers
The water does not completely empty out after cycle is done and the button that says cancel/drain does not empty it out either. this is a kenmore ultra wash about 6 or 7 years old.
Have you cleaned the drain filter ? If yes, then you may have an obstruction in the pump, the hoses to and from that pump or trhe drain hose exiting the dishwasher. Another consideration is the drain system of your house.. are you certain it is not restricting water flow? These are the basic areas of concern and each one ( if bad) can limit the dishwasher from fully draining. Hope this helps..
Sep 18, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
