Question about Nintendo NES Console
My NES console gives us a pink screen red blue black orange teal aqua green lime green light green purple then or black the.
  • Nintendo Master
  • 424 Answers
Well it sounds like that the pin connecter is behind this problem and it needs to be replaced then.
My NES console gives us a pink screen red blue bla - 7_28_2013_1_40_54_am.jpg
Posted on Jul 28, 2013
  • 161 Answers
SOURCE: nes flashing black and white and making a horrible sound
a 'front load' nes ALWAYS does this, even if the connector pins inside the console are new. the cartriges on a Front Load nes rarely completely seat, as Nintendo redesigned the Famicom very poorly for the US market. try this 1. put the cart in as usual, but hold it all the way down 2. slip an unwanted/extra cart in on top of the metal hoop above the cart your using. this gives a better contact for the cart. try cleaning the cartrige pins as well. some won't read right if there's ANYTHING on the pins.
Posted on Jun 12, 2009
  • 11 Answers
SOURCE: Wii Console will not turn off.
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Posted on Jun 30, 2009
  • 39 Answers
SOURCE: green light on my wii console stays on, black
check if everything is plugged in
Posted on Sep 14, 2009
  • 894 Answers
SOURCE: Won't power on
Well those 3 way adapters are bad news then use an offical NES ac adapter for ensured quality.
images?q=tbn:and9gcqetqvc5gikbddemes5qps6piaegwqsqn7hupt1di5fscwfoqzeer9mmq
Posted on Jun 18, 2011
StuartB
  • 807 Answers
SOURCE: Does the original Nintendo NES-001 require a certain AC adapter. Cause I doesn't have the original ac adapter with same spec. My console power light is blinking on an doff. can that be the issuept
As long as it's 9 volt and about 500mA it should be ok. Just seen an original that says 9 volt and 400mA.
The current (mA) can be higher than the original but not the voltage that has to be 9.
1000mA = 1 Amp. So anything over 400mA is fine, but not less.
Posted on Feb 06, 2012
Testimonial: "so If my ac adapter is 12v dc 750ma which is not the same so can that cause powering up issues with the flashing red power light. Or is the system broken "
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
Dec 30, 2014 | Vehicle Parts & Accessories
Locating wiring diagram for radio
Hey found this on www.the12volt.com
NISSAN VERSA AUDIO WIRE COLOR CHART
Brownish-orange(the thickest lead) - 12v Constant
Orange - Illumination
Cyan - Switched Lead/Accesory wire/Ignition wire
Black - Ground
Grey - Right Rear Negative
Teal - Right Rear Positive
Purple - Left Rear Negative
Red - Left Rear Positive
Brown/Pink - Left Front Negative
White - Left Front Positive
Green - Right Front Positive
Red/Blue - Right Front Negative
Jan 29, 2014 | Car Audio & Video
Wiring code for a 1997 ford f150 xlt extended cab
1997 Ford F Series Stereo Wiring Constant 12V+ Green/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Hope this helps.
Mar 13, 2011 | Car Audio & Video
I need a radio wiring diagram
Switched 12V+ Yellow/Black
Ground Black/Light Green
Dimmer n/a
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
best wishes
Jan 01, 2011 | 1992 Ford Explorer
Car stereo wiring color code for f-150 1999
Constant 12V+ Light Green/Pink Switched 12V+ Black/Purple Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 21, 2010 | 1999 Ford F150 Regular Cab
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
I am looking for a stero wiring diagram for a 1997 ford f150
Ground Black/Green
Dimmer n/a
Antenna Right Front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 03, 2009 | 1997 Ford F150 Regular Cab
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Nintendo NES Console Logo
107 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
