Question about Music
Yamaha dgx 500 keyboard
I went to turn on my piano and the blue lcd light started flickering on my piano and i would get no sound when i would play the keys. I turned it off and when i went to turn it back on the piano made a low sound and the lights dimmed and still no sound. Please help! What can I do ? =(
    Problem Solver:
  • 5 Answers
Unplug and leave it unplugged for a while and then make sure the plug is nice and secure on both ends and try again
Posted on Jul 29, 2013
5 Suggested Answers
  • 1138 Answers
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Posted on Apr 28, 2009
  • 5603 Answers
SOURCE: certain keys do not make a sound..
The wire from pin 1 or 7 of CN1 on the GHL88L (left end) circuit board is open where it goes to the middle circuit board. This could be a bad cable, improperly seated cable connector, or a crack in the circuit board(s) connecting to these wires. These are the common matrix wires associated with only the C# and G keys for the left 1/3 of the keys. If more than 1/3 is dead, then the problem is likely on the middle board GHL88M that connects to the mating cable to the CN1 connector.
There are two wires dedicated to the keys for the two contacts that are used to measure velocity of the key strokes. There is a mechanical position between closing the contacts and the time is measured by the processor as velocity.
If you are the least bit worried about working on electronics you best have a service person do the repair. The keyboard has to be lifted out after removing the top and disconnecting other cables.
Posted on May 03, 2010
rommelalilin
  • 2178 Answers
SOURCE: Can I connect a Yamaha DGX-500 piano to an
yes - use two RCA cables from the left and right audio output and connect it to the aux audio RCA inputs of an amplifier or receiver.
Posted on Dec 06, 2010
  • 5603 Answers
SOURCE: as i play notes on
Check if you MIGHT be in a "guide" or learning mode. Some Yamaha synths have a mode that will play and then wait for you to hit the right key before moving on. If this is not the problem, a fix is not DIY and will require repair. I assume you are NOT using MIDI as in that case it is called "dreaded MIDI drone" and is due to data looping back into the unit which is an external fault.
Posted on Aug 18, 2011
How do i reset the keyboard to factory settings? It sounds really weird right now
You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory.
decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
Jul 20, 2014 | Yamaha DGX-230 Portable Grand Piano
Blue LCD screen
I had the exact problem, mine was a YPG 535 brand new in box I put everything together with stand and FC4 pedal. When i got ready to play just a blue screen and none of the red lights came on and no sound, I notice when i was messing with the on and standby button hopeing it would work the speakers would make a popping noise I personly thought it was a manufacturing defect.....i'm sending it back to have it replace. I never had problems with yamaha products but seems like more and more defects are happing with newer portable grand series!
Feb 24, 2014 | Yamaha DGX 640 Keyboard Arranger
Dgx 230 dc in connector bad
This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
If you need a socket Google :
Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
Yamana DGX 630 E keys make strange sound
Perhaps the performance assistant technology is turned on.
Press the [PERFORMANCE ASSISTANT] button to turn it off.
Jan 12, 2013 | Yamaha DGX630 - Digital Piano
The display screen for my DGX 500 is blinking on and off and is unresponsive.
Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
Mar 20, 2012 | Yamaha Music
Can I connect a Yamaha DGX-500 piano to an amplifier?
Dec 06, 2010 | Yamaha Full-Size Keyboard
I am not getting any sound from my Yamaha DGX 200,
From Yamaha DGX 200 Manual
  • Q-There is no sound even when the keyboard is played or when a song is being played back.
  • A-Check that nothing is connected to the PHONES/OUTPUT jack on the rear panel. When a set of headphones is plugged into this jack, no sound is output. Check the Local Control on/off. (See page 69.)
Jul 29, 2009 | Yamaha Full-Size Keyboard
Yamaha P-120 Piano: Graded Hammer (NOT key) dysfunction?
My opinion is you should take the instrument to a yamaha authorized service center.. It's doubtful this will be user serviceable, particularly if the problem isn't on all the keys, and the service center will have access to the parts needed as well as more information from Yamaha than they will share with an end user.
Mar 15, 2017 | Yamaha Music
Apr 20, 2009 | Yamaha Music
Music Logo
132 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
