Question about LG 42LS349C 42" 1080p LED-LCD TV - 16:9 - HDTV 1080p
No power when turn off tv
When I first plug in the tv, everything is fine. After I turn it off it will not come back on unless I unplug it for about five minutes. Does anyone know how to fix this?
    Problem Solver:
  • 13 Answers
VOUS AVEZ DES CONDO AUI ONT PERDU LEURS VALEURS ET VOUS DEVRIEZ LES CHANGES
Posted on Jul 28, 2013
  • 135 Answers
SOURCE: LG 42LC2D WILL NOT STAY ON
I have been rebutted on answering this type of problem from years of personal technical experience, from a guest, no less.
Due to that, my rank fell from guru to wiz.
So, firstly, check to see that the power button on tv itself is NOT being stuck ON or OFF by the cabinet.
Posted on Oct 07, 2008
javswr
  • 44 Answers
SOURCE: tv shuts off after only a minute of play
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain).
If you see this problem, you can buy a new power supply at www.shopjimmy.com or ebay. You will need the make and model, of your tv to order! Good luck, I hope this is helpful!!
Posted on Mar 25, 2009
ramon49
  • 111 Answers
SOURCE: sound but no picture
You popped the plasma HV generator. Do you use a UPC all the time, if not then power line surges or brownouts can cause this type of problem. Needs Pro shop repair, expect around 450.00. PS: buy a upc for around 10 minutes run time $80.00 ??
Please rate!
Posted on Mar 31, 2009
  • 145 Answers
SOURCE: I can not turn on my tv unless I unplug it first
Probably requires a replacement power supply, try swapping for another power cord if they are modular, if not, contact LG support and they will set you up with a part, and an authorized tech to come to your home and install it.
Posted on Apr 03, 2010
budmrtn
  • 11361 Answers
SOURCE: I was watching my LG LCD 42 tv when it went
You may have dying power supply or backlight inverter board, those are the two areas you need to check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 11, 2010
Samsung TV won't turn on or stay on without being unplugged/reset.
Have you tried the main board, its what supplies the signal to the power supply to turn it on and off
Sep 29, 2017 | Samsung Televison & Video
Tip
How to repair a vizio tv that turns off at random
1.) Unplug everything from the TV [power, hdmi, av, and more]
2.) Because the Vizio holds power while unplugged you can reset it while its unplugged.
3.) hold power button on the tv down for about 60 seconds.
4.) plug the power only back in.
5.) turn tv on
6.) if it works then plug each component in one by one
7.) enjoy your tv
8.) start saving for a non vizio tv.
on Apr 07, 2010 | Televison & Video
I have a Panasonic LCD tv, model# TC-32LX70, S/N MY71420839, manufactured May 2007. The tv wouldn't turn on unless the power cord was unplugged and plugged back in for about 2 years. Then it
Fault with the main power supply regulator section circuit board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 20, 2014 | Televison & Video
Will not power on..have to unplug wait till red power light goes off then plug back in ..then will power on fine
Power cycle your TV by unplugging it and leaving it for a few minutes. Plug it back in and turn it on. Restore settings back to factory defaults. If everything else fails, then I would recommend pursuing repairs.
Oct 18, 2013 | Dynex DX-LCD32-09 LCD TV
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
Jul 19, 2010 | RCA Televison & Video
My Hitachi comes on but no cable picture unless I
now do you have a cable box if you do disgard
if not tray to rescan for chanels and after the tvv is done scaning
hit menu
then
setup
then
rest software
then
no for resting the tv to the manufacter setting after going off
and that would take care of the problem
Jul 30, 2009 | Hitachi 42HDS69 42 in. Plasma Television
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Sharp Aquos Won't Power On
I have the same problem with my My LC-42D62U WHen i watch certain DVDs, (so far it happened on SAW III and RUNNING SCARED) during certain parts of those movies my TV will turn off and i cant turn it back on unless i unplug it and plug it back in. It only turns off on specific parts in the movie, i have no idea why...like the same exact parts...so i pretty much have to pause the movie with my remote once my TV turns off then when i power the TV on again just resume the movie and its fine...but if i rewind to that part again it'll power off again SAW III only had one part like that....but RUNNING SCARED had about 3-4
Apr 09, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
LG 42LS349C 42" 1080p LED-LCD TV - 16:9 - HDTV 1080p Logo
48 people viewed this question
Computer Repairing
Computer Repairing
