Need help with a VGA cord
I own a Philips speaker system without the dvd system with it and the input for the sub woofer which connects all the other speakers is a VGA 15 pin connector and i was wondering which pins connect to which speaker?
    Master:
  • 482 Answers
I dont know, but I do know it is a proprietary cord, it is meant to work only with that model of unit
Posted on Jul 28, 2013
I need to connect a subwoffer VGA with an stereo receiver. Do you know where I can find a cable to do this?
i have hts 3455/98 i connect perfectly all cables but sound is coming from only one speaker. pl help me about this problem.
Mar 28, 2013 | Philips HTS3450 System
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
I have a coby CSP96 speaker system. it said on the manual online that i found on the cobyusa.com site that there should be a volume control on top of the sub-woofer but there isn't one there. i can only...
I am having the same problem. I also have the combo dvd and theater system. I also read that the sub woofer is supposed to have a volume control on it but its not there. The only way to control volume is to connect to coby dvd player. This dvd player is beyond terrible. DVD looks bad and sound is miserable. I hooked up xbox 360 to my samsung 52 inch, then on the outputs of my tv into the inputs of the "TV" section on the Coby Sub woofer. At this point great sound quality comes from the xbox and all speakers, but the volume is uncontrollable and is blasting loud. Tv volume control does not work either. I am stuck like chuck and have not found a solution. This has to be one of the worse purchased i have ever made because i am forced to use a terrible DVD player just to get some sound through the speakers. I dont understand why on the speaker systems you buy without dvd combo has a volume control on subwoofer, but on the combo subwoofer doesnt have it. Just terrible. I will continue to look online and try and find a solution other than smash it to bits.
Oct 19, 2010 | Coby CSP-94 Speaker
HELPP!! How to connect ''bush dvdav11k'',to TV without DVD Player
HI,
I TOO HAVE BOUGHT THE AV11K. I TOTALLY HATE IT. ITS LIKE ITS BEEN CO-DESIGNED BY THE EUROPEAN SPACE AGENCY AND THE PLAYER AND WOOFER/AMP DONT FIT TOGETHER.
ID LIKE TO SAY THIS THING IS SO POORLY DESIGNED IT REALLY WOULD BE WORTH SENDING IT BACK FOR A REFUND.
ON THE BACK OF THE PLAYER, AND THE WOOFER YOU'LL FIND LETTERS. IE LF,LB,,,,RF, RB. (LEFT FRONT , LEFT BACK ECT). USING THE 'TULIP CABLES SUPPLIED YOU NEED TO CONNECT THE WOOFER AND THE PLAYER TOGETHER MAKING SURE THE LETTERS CORRESPOND.
DO THIS FOR ALL THE CONECTIONS ON BOTH THE PLAYER AND THE WOOFER. THERE SHOULD BE NON LEFT OVER.
THE LETTERS CORROSPOND THE THE POSSITION OF THE SPEAKER IN THE ROOM. SO ( I ADVISE YOU GET A REAL OF EXRTA SPEAKER CABLE FROM EBAY FOR A COUPLE OF POUNDS ) AND PLACE THE SPEAKERS IN ALL THE FOUR CORNERS OF THE ROOM THEN FILL IN THE NEEDED CABLE TO MAKE IT REACH THE WOOFER, WHICH MOST LIKELY YOU WILL HAVE BESIDE OR BEHIND THE TV AS ITS MOST CONVENIENT THERE ( WOOFERS ARE BASS MAKING SPEAKERS AND DONT REALLY CARE WHERE THEY ARE PLACED IN A ROOM.)
YOU SHOULD BE READY TO GO NOW.
THAT IS IS YOU CAN GET ANY SOUND TO COME OUT THE SURROUND SOUND SYSTEM ( LIKE I COULDNT).
THE SMALLER REMOTE IS FOR THE SOUND. THIS CAN BALANCE LEFT AND RIGHT AND VOLUME. AS WELL AS SELECT A AUX INPUT SUCH AS AN IPOD ECT. ( FOR THIS YOU WILL NEED A SIMPLE 3.5 > STEREO PHONO PLUGS. SIMILAR TO THE ONES USED BY THE AV11K.)
WHY IN HELLS NAME THIS SYSTEM IS ON THE MARKET I DONT KNOW. GOD PLEASE RE-ANIMATE MY LAST, AND TRUSTY PHILIPS DVD PLAYER..
HOPE THIS HELPS ALL UNFORTUNATE AV11K BUYS.
YOURS SINCERELY,
ALEX
Jun 04, 2010 | Audio Players & Recorders
I have just got a Toshiba 37AV502R flat screen tv. I want to connect the digital audio output (optical) to my older 5.1 speaker system. The input on the sub woofer is a 15 pin VGA... I can't seem to find a...
Is this sub a Bose. The only reason you would see a VGA type connector on a sub is if it is dedicated to somthing else such as Bose 3-2-1 system. This is not a standard VGA input and can only be connected the the dedicated head unit. I need more info on the sub. Brand and model. Ther should be an analog audio input on the sub. This will be sufficient.
Oct 31, 2009 | Toshiba 37AV502R 37 in. LCD TV
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Nov 10, 2008 | JVC SPPWA670 Subwoofer
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
Leads
Most of all electronics accessory or parts you can buy it in electronics shop.The leads you said is the RCA cord,input in dvd player output to home theater subwoofer.Tell the shop that you need RCA cord from dvd player to home theater sub woofer.Or you can order it in the site just type googles and search for electronics accessories.That's all jon-jon txt me what the result.
Jun 14, 2008 | JVC TH-M505 System
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
50 people viewed this question
 Grubhead
Grubhead
