Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
Set thermostat I want to reset the thermostat to normal I don't want it running on any programms
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
How do I turn down my thermostat?.
I think you may be misinterpreting what it's telling you. The up down buttons select the DESIRED temperature, when it goes back to the same number it's showing you the actual temperature, which given time should eventually reach the desired temperature.
May 09, 2014 | Ouellet Heating & Cooling
How to reset thermostat
I am not familiar with this particular thermostat; however, here's some general information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
from my understanding there are two types: programmable and non-programmable.
setOFF manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Apr 24, 2014 | LG Dryers
Trouble shooting codes
Code Error 53 is "defective outdoor sensor" error.
source: search engine keywords - Code Error 53
I am not familiar with this particular thermostat; however, here's some general t-stat information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat for the group. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
disable auto & enable manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Apr 12, 2014 | Honeywell Programmable Thermostat Heater
Installed an rth2510 and installed as labeled on old stat and sounds like my ac nut is buzzing outside, any thought?
question: do you have a multiple thermostat setup in 1 zone? If so check what settings are for your heat on each thermostat. Make sure that the heat is not set higher than the room's temperature.
check what settings are for your cooling on each thermostat. Make sure that the cooling is set accordingly.
if you have multiple thermostats setup in 1 zone. the thermostat with the lowest temperature will reign supreme. The heat setting on that thermostat will be what's causing the buzz on the heater.
optionally, hard reset your thermostat as a precaution. Here's how to do so: there are two types of thermostats i know of programmable and non-programmable.
disable auto & enable manual; however do NOT change settings or power-off t-stat. Remove battery and power down the thermostat until you see nothing on the thermostat monitor; power OFF the switch connected to your t-stat. Remove battery and reinsert inverted, if needed, press whatever button that your heart desires to make sure that nothing is absolutely drawing into that mode, button, etc; wait (5sec-1min); remove batters; wait 1min; then, reinsert batteries in its correct position; if you have a programmable thermostat; do the same with the hit 'reset filter' held down observe if the roomTemp reading has changed.
May I suggest to keep an extra thermometer around to determine if temperature reading accurately?
If reset requires a reprogramming to your t-stat, do whatever required to set your desired setting.
cheers, best of luck. i hope i've helped.
background, doing a hard reset in my opinion is similar to removing the battery from a PC motherboard.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
