Question about Maytag MDB7130 Dishwasher
Repair manual Found a black round flat piece of rubber with a hole in the middle. Not sure where it came off. Just sitting at the bottom of the dishwasher. Where does this go?
4 Suggested Answers
SOURCE: Skybox parts # 4387535 installation issues
You don't need to keep the round metal piece or the black wire that you take. The replacement part (flat one) is installed in its place. Put it in first, attach the green wire to it, and then put the two prong piece and install the wires (blue, white and brown) as you took them off the original part.
Posted on Apr 20, 2009
  • 154 Answers
SOURCE: Our maytag performa top load washer PAV2200
Check the drain hose from the drum to the pump assembly. Alternativly look for the large capacitor that should be mounted to the internal framwork of the machine, see if has popped. They can make quite a bang when they go,
Posted on Jun 21, 2010
  • 884 Answers
SOURCE: PAV2300 agitator bolt keeps coming loose
Loctite sounds the order of the day. Don't overtighten once the thread lock is in place and allow to cure before using machine.
Posted on Apr 23, 2012
Hi there, The rubber mount that holds the front left incicator on my 98 ZX9R Ninja broke. Have a new one but not sure how to replace it. Do the wires come out of the indicator? if so, one of the wires has...
Yes the wires slide through the mount. I'm not sure what you mean by flat round piece of plastic, unless it is a washer or bushing of some sort. If you have to, you can cut that one wire, pull it through and the reconnect it with an insulated **** connector after you make your repairs.
Hope this helps.
Jul 12, 2011 | kawasaki Ninja Zx7r Zx9r '94 To '04
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
My steamvac wont pick up the water. it is spinning and blowing out the water, but it wont **** it back in
The most common reason for lack of pick-up is that the lid is not seated firmly on the recovery tank. Lack of pick up is always caused by an air leak. A less common possibility is that the large round rubber seal that the recovery tank sits on has fallen out of place. If you look at the bottom of the tank, you will see a round hole. When you install the tank, this hole sits on top of a rubber seal on the motor shell. Be sure the seal is in place.
Feb 05, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I found a small part #8519736 sitting on the bottom of my dishwasher. I'm not even sure where it came off from. 1. Where does it fit back on? 2. What holds it on 3. Can I replace it myself or do I...
Sorry - this isn't a solution, just a "me too."
I wasn't even sure the piece was from the dishwater, so at least you settled that.
I found the part on top of the bottom rack of dishes, so I looked at the top rack and the top of the interior. I suppose water pressure could have moved it from the lower part of the washer, but what are the odds? I didn't see anything in the top half of the dishwasher that looked like a part came off.
For the guru's out there, it's a piece of rubber/vinyl (SAE PA66), 2.5 inches x 1.5 inches.
I was about to attach a photo, but I have to learn to decrease the file size first.
Jan 27, 2011 | Whirlpool GU2400XTPS Built-in Dishwasher
Opening the PL-Z81 box after standing packaged for quite some time -I saw that the turntable had come apart and that there were four pieces - a silver dish (the turn table) --the rubber mat that sits on...
Ok! On the main part of the turntable should be a spindle, not the one in the middle! That if you put your finger on will turn. This is the motor. On the underside of the silver dish should be a flange. Place the belt round it and put the platter on the center spindle (the one in the middle). If the platter has a hole in it, grab the belt and pull it, while rotating the platter till you can see the motor spindle. Attach the belt to that. Put the rubber matt on and try it out.
The black piece is for 45's with big holes in them (jukebox ones).
PS if the platter hasn't a hole you will have to put the belt on the motor spindle first and then around the flange (try not to pull the belt to much).
Also some turntables pass the belt via a leaver that lifts the belt up and down for 45 and 33 speeds, others just change the motor speed.
Aug 23, 2010 | Audio Players & Recorders
The middle arm on my dishwasher (ge Profile) is not turning...the top and bottom are working fine
Had same problem with mine. Actually bought all new middle arm assembly but as I was taking it apart to install new pieces, I noticed so much gunk in the middle swinging mechanism that I assumed that must have been the problem.. I really think the newer dishwashing tablets cause this buildup problem. Anyway, put on all new pieces and started the machine. Long story short, it worked great for about a month and then started doing the exact same thing. THE reason why the middle arm sprayer doesn't spin is that the little holes at each end (the ones that sit underneath and look like they should propel the sprayer arm ) get clogged. I bought some pipe cleaners, bent to an angle where I could come in from the top and pull out through the propellor hole and voila` the sprayer is swinging beautifully again.. I guess the only question I still have is why this started happening three to four years after I purchased the machine. Something somewheres else must not be doing its job.
May 18, 2010 | Dishwashers
My dishwasher used to clean very well, but is now leaving debris in my glasses and bowls. There is also a loose piece I found in the bottom of the dishwasher, not sure what it is for! The dishwasher is...
see if the sprayers are rotating(see where the arms are and start it, then open it to see if they have moved, the machine will stop when the door is opened)if not, remove the sprayer arms and clean them as best you can (make sure all the holes are clean) the arms can be removed by turning the x shaped thingy in the middle of it
Jan 10, 2010 | Whirlpool GU2700XTSB / GU2700XTSQ /...
The cartridge keeps getting jammed on the left side and when it prints the left side is printing double. I found a small black rubber piece rectangular shaped but with 2 square corners and rounded on the...
I will replace the printer. There are so many on sale now, I'm not going to waste money trying to fix it when I can get a new one for what it would cost to fix it.
Dec 18, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
Maytag MDB7130 Dishwasher Logo
42 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
