Question about 1996 CHEVROLET SUBURBAN 1500 Grille a1v287980 Chevrolet, composite h
1996 chilton repair manual for transmission for 1500 suburban 2 ton
Transmission repair manual
You need to buy an ATRA manual for your unit or trans
They have a web site (ATRA.Com)
Should be about $29.95
Any other material is useless
Posted on Aug 26, 2013
How can I get a 99 1500 suburban motor and transmission to wire to a 98 1500 pickup?
same transmission? same engine? 98-99 was the cut-over year for changing small block chevy motors
Nov 28, 2013 | Chevrolet Cars & Trucks
Where can i find a book on a 1996 dodge caravan transmission rebuild
If you go to your local library you can check out a Chilton manual or any other good book on chryslers. I have used them TONS of times for my 03 Caravan.
Chilton is usually the most informative book.
Mar 06, 2011 | 1996 Dodge Caravan
On my 97" Suburban do
It depends. For a regular 1/2 ton and most 3/4 tons no, just remove the caliper and the rotor comes off over the wheel bearing hub. 1 ton suburbans, require more work, you will require a large socket to remove the axle nut, and a slide hammer or 3 jaw puller big enough to pull off the rotor and wheel bearing as an assembly. The rotor on some 3/4 tons and all 1 tons bolt from behind thru the wheel bearing and need to be removed together. The wheel bearing has to be unbolted from the spindle, then the wheel studs have to be punched thru to remove the rotor. The splines on the wheel studs hold the rotor to the wheel bearing. 1 ton will say 3500 on the side, 2500 for 3/4 ton and 1500 for 1/2 tons.
Jan 31, 2011 | 1997 Chevrolet Suburban
Sprak plug Wires Need To Be Installed Correctly
You have several RAM sub-models in here:
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} B1500 RAM Van
B2500 RAM Van
B3500 RAM Van
RAM 1500 1/2 ton 2WD
RAM 1500 1/2 ton 4WD
RAM 2500 3/4 ton 2WD
RAM 2500 3/4 ton 4WD
RAM 3500 1 ton 2WD
RAM 3500 1 ton 4WD
Chrysler Full-Size Trucks 1989-1996 Repair Guide
To avoid confusion, remove and tag the wires one at a time for replacement.
Fig. 1: 2.5L 4-cylinder Engine. Engine Firing Order: 1-3-4-2. Distributor Rotation: Clockwise
Fig. 2: 3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise
Fig. 3: 5.2L and 5.9L V8 Engines. Engine Firing Order: 1-8-4-3-6-5-7-2. Distributor Rotation: Clockwise
Fig. 4: 8.0L V10 Engine. Engine Firing Order: 1-10-9-4-3-6-5-8-7-2. Distributorless Ignition
Hope helped with this (remember rated this help) Good luck.
Nov 06, 2009 | 1996 Dodge Ram
Where can I get a manual for a Chevy 1993 1500 series-350 V8 1/2 ton Sidestep. Currently I don't have a manual for this truck. Problem is I don't know how to set the time on the clock.
eBay would be the best bet
check out this past auction
http://cgi.ebay.com/ebaymotors/1992-1993-CHEVY-1500-2500-3500-REPAIR-SERVICE-MANUAL-CD_W0QQcmdZViewItemQQ_trkparmsZ65Q3a13Q7c66Q3a2Q7c39Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem5633486174QQitemZ370227569012QQptZMotorsQ5fManualsQ5fLiterature
email the seller asking to relist it.
Jul 18, 2009 | 1993 Chevrolet K1500
1996 suburban fuel injection
understand this is only a estimate, base on you have all the tools and parts. If this is your first, you are looking at approxmiately 8 hours. no include testing and readjust.
May 20, 2009 | 1996 Chevrolet Suburban
Transmission swap
yup, the motor and drive train are the same... if the wheel base is the same between the two trucks, than you can also use the drive shaft from it too
Feb 27, 2009 | 1996 Chevrolet K1500
Rear end cover rusted out
The Previous Solution that I sent you was Straight from the Chilton Repair Manual.
Feb 01, 2009 | 1999 Chevrolet Silverado 1500
1996 CHEVROLET SUBURBAN 1500 Grille a1v287980 Chevrolet, composite h Logo
95 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
