Question about Vehicle Parts & Accessories
Can you put an engine block heater on a 2004 f-150 non-heritage model fx4
  • Vehicle Part... Master
  • 14,036 Answers
Block heater mostly for diesel engines.living colder climates use 5W - 30 ENGINE OIL make sure you 50/50 coolant and water mixture or add little more coolant if you live in zero temperatures have strong good cold cranking AMP battery cold start ups should be no problem.add fuel treatment to fuel to keep out water.
Posted on Jul 28, 2013
Where is the connector located for my heat knock sensor
Confused on your question. If you are looking for the plug for your block heater, it should be on the drivers side of the block,towards the front of the engine. But keep in mind that a block heater is an option and not all trucks, especially non diesels, will have one. If you are looking for the knock sensor connectors, there are 2 of them and they are under the intake manifold. It will have to be removed to get to them.
Jan 24, 2017 | Cars & Trucks
No heat in F-150 could it be thermastate
-No. not the thermostat. Here there are couple thing that cause the heater not blow hot when you need hot.
1. Water line to the heater core is plug, or the control valve is not open due to broken linkage (Cable).
2. The vent butterfly stuck in cold air position.
Good luck
Mai
Feb 04, 2014 | Maisto 2004 Ford F150 Fx4 Pickup Truck...
Hrabour pushing Tug, fitted with 2 Main engines 3516 b, One is non operationalsince last 2 Months Should have taken any special precautions except turning through turning gear. The other one starts daily...
White smoke on a diesel when it just starts indicates low compression. Most likely excessive ring gap until some heat is generated to expand the block and pistons.. It's overhaul time.
Oct 31, 2013 | Caterpillar 3516B DITA Marine Propulsion...
Old Lady here... Be KIND, Please! Where is the plug in thingy for the heater on the engine? We are at -9 and I can't find it. Thanks for any help.
The thing you are looking for is called a block heater and most vehicles dont come standard with them. Mostly people put them in after market. But if there is one, it will be in one of the bigger radiator hoses in the front. Probably on the very top or very bottom of the motor. Obviously look for a hanging cord to plug into. Other than that, i wish i could help ya. Maybe try reposting with the make and model of your vehicle. good luck
Feb 26, 2011 | GMC Sierra 2500HD Cars & Trucks
My natural gas heater is putting black soot out all over my walls and ecerything else. Could you tell me what the problem is and what to do about it?
It needs a service asap soot gives off fumes do not use it , It could be blocked air ports on the burner , burner blocked , blocked injector , burning at wrong presure , blocked flue .
Any of these but get it serviced this will all be checked when you have it done .
Feb 12, 2011 | Heating & Cooling
Dealer recommended a "block heater plug
engine block has a place to put an electric heater to keep engine from freezing in northern winter climates. The heater is optional, so they put a plug there when you don't ask for a heater. If the plug rusts out, you will lose your coolant, but I don't think it would be sudden. They usually start with a small hole and you'll see puddles before it goes completely. It should not cost a lot for this repair, even if you decide you want the extra insurance. OK?
Oct 30, 2010 | 2005 Dodge Grand Caravan
Were is the drain plug located on a 2007 chevy 5.3 on the passenger side of engine . is it behind the ac unit. i want to put a engine block heater in.
The block drain is on the passenger side of the engine, in the center of the block near where the oil pan attatches to the block.
Engine Block Plugs/Sensors
100 - Engine Block
100 - Engine Block
101 - Oil Gallery Plug - Front
110 - O-Ring
111 - Oil Gallery Plug - Rear
112 - Oil Gallery Plug - Side
113 - Washer
114 - Engine Coolant Heater
115 - Washer
116 - Oil Gallery Plug - Side
117 - Washer
130 - Transmission Housing Locating Pin
145 - Washer
146 - Engine Block Coolant Drain Hole Plug
701 - Crankshaft Position (CKP) Sensor
702 - O-Ring
718 - Knock Sensor
718 - Knock Sensor
739 - Bolt
739 - Bolt
750 - CKP Sensor Bolt
Oct 19, 2010 | Chevrolet Silverado 1500 Cars & Trucks
A/c , heater blower not working but a/c & heater are working
No fuse. Newer vehicles have BCM Body Control Modules. Everything is computer controlled. Take it to a shop.
Sep 27, 2009 | 2004 Ford F150
Can I put an engine block heater in my '99 Subaru Legacy?
you should be able to i think they are referring to the newer models of subaru 2001 2002 and up.
Jan 13, 2009 | 1999 Subaru Legacy
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
