Question about Dryers
Switch knob came off
The switch knob came off and the pin seems to have a spring I am unable to put it back, Help please
    Genius:
  • 1,617 Answers
Need to get a new one.
Posted on Jul 28, 2013
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
Mar 22, 2013 | Westinghouse Electric Westinghouse...
Mixer won't turn on. I had the pin problem everyone describes. Finally was able to get the pin back in with some serious hammering of the pin and then tightened the set screw on the bottom. Fabulous!...
They are the brush springs. The brushes get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I have an emtek key in knob lock and wont disasemble
The locks are tricky, they have special tools to make it easier, I'm not saying you can't do it, but if you can't get the knob apart, I don't know if you can get the pins in the tumbler right. Usually a pin hole in the side of the knob will release the keyset, then the ring in the back will release the tumbler, the cap on the top will release the pins, and I mean release, hang on to them, cause they fly! Put the tumbler back in without the pins, put the new key in, make sure it is right, drop the pins in one at a time, first the bottoms, they should all be the same size, then the tops will be according to the cut in the key. Or is it the other way around, drop in the springs, put the cover on, if it works the first time, you will be very lucky. Hope this helps.
Mar 20, 2010 | Top Knobs M826 Door Pull
The pin on the starting switch broke. Black and Decker CMM120
Same problem with ours. We used a bolt (cut to fit with dremmel tool) to replace the pin and the spring slipped over the bolt. I don't remember exactly where the two arms of the spring met the switch and handle, but it was obvious once the spring was on the bolt.
Aug 31, 2009 | Black & Decker 19" Electric Lawnhog...
Timer knob assembly, how to disassemble and assmble back together
It sounds like the only thing you are missing is the circlip to hold the whole lot together.
With it de assembled you should see a cut out part on the timer stem that's where the circlip goes when it's all back together
Jun 11, 2009 | GE Washing Machines
Need to repace a knob on a colmans water heater
I've just done that. The shorter leg of the spring must go into the knob. You will see two thicker mouldings in the knob where the spring fits ...v shape. The longer side of the spring goes between the two raised bits on the insert to the knob. The insert can only go two ways and the depressed portion must be at the top so that it is not pushing the micro switch in the off position. Assemple the knob, spring and insert before screwing to the unit.
Mar 18, 2009 | Coleman Hot Water On Demand
How can i fix my bosch gbh 4 dfe?
Yes, there is a trick to it. Make sure the pin is placed inside the little weird looking spring inside the hole. Press in the selector knob at about the five oclock position and rotate counter clockwise. Lemme know if you need further assistance. Please rate me
Feb 25, 2009 | Bosch Drills
A/C - Heat Selector Switch spins to the Heater red zone only
sounds like the little splines are worn take it off and try put some copper wire in the spline it might help jam it into position. if this helps please rate me
Nov 21, 2008 | 1998 Jeep Cherokee
Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Dryers Logo
Top Dryers Experts
