Question about Garden
How to replace pull start cord - Garden
    Sergeant:
  • 337 Answers
Hi Eric. Firstly remove the starter head then turn it over. Turn the inside disc anti anti clockwise until the spring stops turning. Get some help from someone else to thread the new cord through the spigot and tie two knots in the end together. Slowly release the spring and the new cord should go into the starter. Job done. replace on the mower and off you go.
Posted on Jul 29, 2013
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
Can a pull cord be replaced on a briggs & stratton 2300 psi gas pressure washer
yes take the top cowling cover off that houses the pull start normaly 4 to 6 bolts around the lower edge of this & you can pick this cord up from most diy stores or tool rentle firms just be carefull when the cowling is off that the cord spool/pully will most likely be under spring pressure unless the cord as broken completley hope this helps
Aug 16, 2014 | Garden
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
Very hard to pull cord
Hi Marco:
You're not alone with that problem. My 266 will barely pull over after sitting for a few days. After a couple of pulls it loosens up and starts fine. Hot starts are also easy. It did not completely solve the problem BUT THIS SURE HELPED. I took the starter assembly off the saw. The narrow reel that the pull cord feeds into had spread which allowed the cord to wedge in against itself. I replaced the reel and here's the important part, MAKE SURE YOU USE A LARGE DIAMETER PULL CORD. That way the cord will lay on top of itself and will not wedge the reel apart.
Gotta love those old Husky's!
Mar 15, 2012 | Husqvarna Models 61-66, 266, 268, 272
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Apr 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Pull cord stuck to motor housing
Ok You have to release the engine brake. BY pulling down the bail to the handle as if you were going to start the engine. Hope that helps.
Oct 21, 2009 | Garden
Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Jun 21, 2009 | Karcher 2500 PSI Pressure Washer
Spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
May 23, 2009 | Mantis Little Wonder Tiller/Cultivator...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
