Question about Chi Health & Beauty
Flat iron light won't turn on, doesn't heat up when plugged in, wont turn on at all when plugged in.
adnanbhatti
  • 1188 Answers
SOURCE: iron has light on so power is there however iron
You will need to dismantle your iron. Follow the instructions below to locate the fault:
a. Make sure the power cord is not damaged.
b. Then, check the temperature selector. If it is in the correct position, something else is wrong.
c. Check the thermostat. As you disassemble the iron, clean the lint from the thermostat. Then test it with your ohmmeter. Set your ohmmeter on RX1 and clip the probes onto the terminal. Take a piece of wood or plastic and move the contacts open, then closed. When it closes you should see the ohmmeter just from high to zero. It so, it is working well.
d. Test the heating element. Do this by removing the base of the iron. There you should see the probes. Take you ohmmeter, set on RX1, and touch the probes. If it reads between 10 to 25 ohms, it is working correctly.
e. If you have an electronic iron, the only other possibility is the circuit board. If you have exhausted your options, take the iron to a professional.
Thank you.
Posted on Sep 28, 2009
heatman101
  • 43501 Answers
SOURCE: f2000 iron won't heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
SOURCE: Brand New Chi flat iron! No light, no heat, no
Have you checked it on different plug ins? I realize this sounds silly, but I had the same problem once and had a fit...all to find out my plug in had tripped. Bathrooms usually have those plugs that have the little button to reset the current. Maybe if you try that and different plugs.... If not, I would take it back as it is obviously defective. May have a bad connection, short, bad fuse, etc, and you would not want it anyway because it would not be safe.
Posted on Jan 05, 2011
heatman101
  • 43501 Answers
SOURCE: my iron won't heat.
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Posted on Jun 26, 2011
  • 12 Answers
SOURCE: My Iron will not turn
Has found all with detailed operation and with comment that from itself this model.Manual HERE
Posted on Jul 29, 2011
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Croc flat iron won't turn on
You might visit www.flatironrepairs.com and contact them to see if they could repair it. It's only $46.00 for the repair + s/h.
Dec 04, 2012 | Crocs Croc Infared Flat Iron 1"
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Wont turn on
see this steps and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Oct 01, 2012 | Irons
Rival IR600 Iron Does not turn on, not heating or lights on ?
see this causes, and use the common sense.God bless you
Sep 19, 2012 | Rival IR600 Iron
Does not turn on
please see the causes and use the common sense. God bless you
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
My iron won't heat. it has electricity but won't heat
Jun 25, 2011 | Rowenta DE-480 Iron
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
Health & Beauty Logo
Top Chi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Chi Health and Beauty Expert? Answer questions, earn points and help others
