I have a rockola ultra 37 and after moving it the records are not playing at the correct speed.it seems to be to slow about a quarter if the turn of the record...anyone have any advice????
  • Audio Player... Master
  • 5,484 Answers
I would assume that the belt has moved off it's correct place.
Posted on Jul 29, 2013
  • 8 Answers
SOURCE: AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Posted on Aug 18, 2009
SOURCE: Strange speed
Don't have a solution, but similar problem...turntable is too fast on 33, and even faster on 45 rpm setting. Turntable had not been moved...just played fine one day, and berserk the next..There appears to be some sort of adjustment on the motor but don't know for what, and without a calibrated strobe don't know how one would adjust anyway, even if one could. Agree it's probable just a crappy motor/design.
Posted on Jan 01, 2010
  • 834 Answers
SOURCE: Plays records too fast. Is
The speed control switch is located next to the tone arm, and here is an image to help assist you, and you can download an operation manual pdf from this site if you would like to have the operation manual for that turntable.
http://www.jackandfriends.com/manuals/CR248.pdf
Posted on Sep 26, 2010
sbachman
SOURCE: my jvc AL-A151 spins records too slow but gets better
I had this problem. In my case it manifested itself mostly in start-up, and I found that I had to move the tonearm past the 1st track to get the TT to spin. I cleaned the contacts on the micro-switch (on the mechanism, from below) with extra-fine sandpaper. It worked.
Posted on Feb 09, 2011
stereophile
  • 36 Answers
SOURCE: AFTER adjusting the speed setting
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
Posted on May 15, 2011
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Slow playback after recording.
Quality is definitely a factor here. Set tape speed to SP. Standard Play. It uses the most tape, and use a newer tape if possible.
You can also try converting to a newer format like MP4. This is the new standard for web videos. Older codecs might be an issue.
Sep 30, 2012 | Diamond Multimedia VC500 One Touch VHS...
No read no write
One possible source of difficulty is there are different blanks for "slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed" recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers had to change the way the discs were made to accommodate each successive improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks with a firmware upgrade, but there is no advantage to doing so since you're still limited to 4x recording (unless, of course, you're unable to find "slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed", "Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks for your drive.
Jan 15, 2009 | LG (GCE-8527B) CD-RW Burner
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
56 people viewed this question
 Grubhead
Grubhead
