Question about Casablanca Fan S3 93045
Casablanca Ceiling Fan Stays On
Recently my fan stays on even if I push the off button on my Versa Touch remote. If I take out the battery and leave it out for a while when I put it back it will turn off when pushing the off button on the versa. Any ideas how to fix this issue. In addition the fan works but there is no difference between med and high speeds, not sure if this is all related. Thanks. Paul
  • 2 more comments
  • Paul OToole Jul 28, 2013
    When the fan will not shut off it makes a weird sound like a cracking or humming sound. Normally this is not an issue and only make this sound when it will not shutoff.
  • Paul OToole Sep 16, 2013
    All went well, the coil did not need to be connected to as it is either in the new receiver or not required. Black and white connected to black and now the fan shuts off; works on all speeds and the light works correctly. Thanks for helping out this non-handy man.
    So ordered a replacement/upgrade kit from Casablanca directly. Total cost was $136.00 and changes including shipping to southern Ontario address. Not too bad seeing the fan originally cost $900. Being plug and play easy install for a novice like myself. thanks for all the help, much appreciated.
  • Paul OToole Nov 02, 2013
    Ending up ordering a replacement receiver kit from the manufactor directly. Installed and all works. Thanks for the help.
    Genius:
  • Casablanca Fan Master
  • 1,617 Answers
Might need a new receiver.
Posted on Jul 28, 2013
Testimonial: "I will try putting in a universal receiver, there is a kit at my local hardware store that comes with a remote also for $40. Its a smaller receiver so it should fit no problems. Thanks for the advice David. I will post back with the results."
  • Paul OToole Aug 14, 2013
    Well that what I will do replace the receiver. Will post back with the results.
4 Suggested Answers
  • 37 Answers
SOURCE: Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Posted on Jan 24, 2009
  • 4 Answers
SOURCE: When the Casablanca fan remote
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Posted on Dec 01, 2010
SOURCE: Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Posted on Jun 22, 2013
Casablanca Visa-touch fan
most problems solved with new batteries
Jul 31, 2013 | Casablanca Fan Versa Touch2 W-72 Remote...
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
Dec 01, 2010 | Casablanca Fan Dryers
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Jun 25, 2008 | Casablanca Fan 3245T Ceiling
Dryers Logo
73 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
