Have a fisher and paykel washing machine with control board 420048-g this board has component damage burnt out resistors and a burnt out u241 chip is it worth while buying new board or just buy new machine ??
the dr
  • 447 Answers
SOURCE: Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Posted on Jan 18, 2008
SOURCE: I have a Fisher & Paykel MW512 washing
Look if you can get a switch that works, is safe, & you can get it attached to the broken board & the broken board itself doesn't stop it alone, then yes I see no reason why not?
Posted on Feb 15, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
SOURCE: 708 Fisher and Paykel washer
usually when this happens, the extra current drawn to Burn the PCB traces, usually ends up damaging other IC;s and thing too.I would expect, that whatever caused that to happen, did you find and fix the actual cause? Or did you just replace the bad board? As if you simply replaced , then the existing problem may still exist, unless it was that board and nothing else. In any event, the Spikes, & Surges produced when things Arc, & Burn, electrically, well these can damage or even destroy the delicate IC's. I think that this is what has happened here. I am sure that a new controller board will fix your problem. please ensure ALL sensors are tested and prove OK. Please check ALL power levels on the Power Supply, as if these are not correct nothing else can be.
http://www.howtomendit.com/search.php?keywords=fisher+paykel&page=7
http://www.appliancerepair.net/apnet/frameset?
http://www.appliancerepair.net/apnet/washer/toc.htm
http://www.letsfixit.co.uk/html/washing_machine_faq.html
These links above are just great for the Home Fixer invaluable have a look, you will be pleased.
Posted on Mar 24, 2010
  • 67 Answers
SOURCE: fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
Posted on Apr 18, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Error 49 on a Fisher and Pykel washing machine, what can i do to resolve this?? Thankyou.
Your cold valve is faulty. The rubber membrance inside the valve can damaged after certain period of time. The problem may be inside the controller if replcement valve can't fix the problem. There is a resistor on the current path to the valve. It is on the control board. Some timems it can go open. Good luck with the repair
Regards
Sarath
Apr 15, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Washing maching won't run any more due to water overflow
completely dead? water onto electronic components. it will need to be physically inspected and electrically tested, and replace motor controller board.
Nov 14, 2013 | Fisher and Paykel Fisher & Paykel Washer
After a circuit diagram for a Fisher & Paykel Intuitive eco. the main board . Ithink itr is a fused link or a resistor fused link, Board no. SD11 PCB 420048-G Regards Ralph B
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct but some will only supply to registered agents ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 06, 2011 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHING MACHINE FAULT CODE 56 DOES ANYONE KNOW WHAT IT MEANS
Error code 56 is mostly the motor controller, SD11 & SD12 brown boards, 3 x 332k resistors near the small transformer go low & need replacing with a 1 meg Ohm resistor will fix the problem.
May 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher paykel wash machine model gwl15ys none of the lights will come on.there is power to receptical.
It sounds like the motor controller board has failed, these are not repairable as they are all surface mounted components and not made to be fixed. Looks like a call to the serviceman unfortunately
Oct 24, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault 49 smartdrive
My paperwork says fault #49 is hot and/or cold water valve faulty. Check that the valve harnesses are connected connected correctly or check that the valve is not an open circuit.
May 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
