Question about Video Game Consoles & Games
Corsair h50 I want to know wish is the better direction for the fan on corsair h50
  • 27,725 Answers
The installation and use of cooling fans in PCs is pretty straightforward once you understand the airflow layout and mechanical assembly.
You need to learn the necessary skills to make sure you are setting up your fans to direct the air where it will do the most good, as well as how to choose (and mount) the correct fan(s) for your situation.
Computer fans are manufactured in five distinct varieties: case fans, expansion-slot fans, hard-drive coolers, CPU fans and external drive-bay fans.
With case fans, there are several physical sizes that are measured in millimeters.
Another measurement the manufacturer will provide is the CFM (Cubic Feet per Minute) the fan is rated for.
As a general rule, the smaller the fan in size and the higher the CFM rating, the more noise it will create.
Before you purchase additional fans, open your case to see what kind of fans can be added.
The fan size must match the size of the opening in the case to be at peak efficiency.
You will need to establish you have expansion slots available if you want to add an expansion slot-style fan.
It is crucial you establish a pathway for the air being moved inside your case to follow.
As an example, having all the fans blowing air from the outside of the case to the inside is not as efficient as having fans on the front of the case blowing cool air in while the fans located in the back of the case are sucking out hot air.
It is recommended the best practice is to position a case fan in the front bottom of your case (bringing in cold air) and at least one fan mounted midway up the rear of your case (expelling hot air).
If possible, use two fans in the back to expel the hot air as a lot of it is being introduced by the CPU cooling fan.
The mounting of case fans is done by using four course-thread screws usually provided with the fan.
These screws are self-tapping and will be inserted through the hole in the case wall created for a case-fan screw, then screwed into the case-fan body mounting hole.
Make sure you use all four screws to hold the fan securely.
The installation of an expansion slot fan can target specific areas where heat is generated.
When mounting one of these fans, make sure the expansion slot fan is not in direct competition with the fan mounted to a video card.
Having the expansion slot fan blowing directly into the video card's fan, which is trying to blow out air, will defeat both of the fans' purpose.
Hard-drive coolers usually mount to the circuit board side of the hard drive and work to keep it cool.
Because of the location of most hard drives, there is very little disturbance from the air that is released from the hard-drive cooler to the airflow pattern mentioned earlier.
External drive bay fans can provide an enormous amount if airflow, assuming there is an external drive bay open.
http://www.homepcbuilder.com/lessons/installation/lesson04/lesson04.html
Posted on Jul 28, 2013
I have a asus z87 deluxe dual and just got the Noctua NH - D14 SE2011 will it work
Yes it will work, It just won't fit on the socket 1150 motherboard. In other words it is no good for that motherboard as the fan is for just about every CPU socket except yours. Plus the area around the CPU socket on that board is confined for such a large fan unit. You could get a liquid cooling system from corsair that would cost the same and do a better and quieter job.
Aug 04, 2013 | Computers & Internet
If i replace an old PSU 12V 0.12A fan with a new 12V 0.13A fan will there be problems?
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
This should not be a problem.
A new bigger power supply, is always better than the factory one.
This will give more stability.
Try to buy a well known brand, like corsair.
Good luck
Jan 31, 2013 | ASUS P5KPL-AM SE Motherboard
I have a sony syber shot dsc - H50 i don't know how to get the cam in "manual focus" mode. I want to shoot 1 cm far images.
One problem with most point&shoot cameras is that they are designed to be pointed and shot. The camera takes care of things automatically, including focus.
The H50 doesn't have a manual focus mode. The best you can do for close-ups is to switch to one of the Macro modes. Press left on the control button (marked with a blooming flower) repeatedly to select the desired mode. See page 18 in your manual for full details.
Jul 14, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
Quick question - just bought my sony H50 today and can't figure out how to do panorama shots. Does not say in the manual. Do you know how? Many thanks ! Lisa )
Sorry, unfortunately the H50 doesn't have in-camera panorama stitching... you'll have to just take a series of shots and use something along the lines of Adobe Photoshop Elements to stitch everything together - the closest I could find was a 16:9 setting within the camera, but that's just a close crop, it doesn't produce a true panoramic shot.
Please rate this solution if you've found it helpful! Thanks!!
May 12, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
May 05, 2009 | ASUS Computers & Internet
Looking for instructions for lcd replacement Sony h50
We don't provide instllation instructions but if you need to buy the part our price should be much lower than buying it retail from anywhere else.
Do a Google search for "digital camera parts" the website name is Darntoothysam com. If we can help please let us know!
Thomas D.
Owner, Darntoothysam com
Apr 28, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Video Game Consoles & Games Logo
98 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
