Question about Horizon Exercise & Fitness
Lube Belt or Bed
I have a T-3000 universal unitrack treadmill that keeps coming up with Lube Belt or Bed I have taken cover off but there is nowhere to put lube I have looked for manuals online for the T3000 model and cannot seem to find any can somebody plz help with the problems cheers Alby
    Top Expert:
  • Horizon Master
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Jul 28, 2013
  • 12 Answers
SOURCE: lost lubing instructions for treadmill and tool ex wife took them
Horizon fitness sells silcone gel lubricant or many stores also carry it.
Gerritt
Serving the Twin Cities
Posted on Mar 13, 2009
SOURCE: Horizon CT-81 treadmill needs lube
100% Silicone Oil; 1000 weight viscosity :)
Posted on Jan 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: Lube Belt displays on digital display how to reset
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Posted on Jul 29, 2010
  • 14 Answers
SOURCE: treadmill says to lube belt,
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
Posted on Oct 25, 2010
SOURCE: horizon treadmill won't start running
power going to treadmill. it is beeping the whole time but wont start or move
Posted on Jun 14, 2011
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
I have got a dynamix kp329 treadmill when I stand on it,it keeps stoping,is there anybody who can fix the dynamix,i cannot find anywhere that can fix them.
see the video and lube the deck belt,This happen because the system protect the electronic system. By lack of lube and maintenance. YOU must lube too the rollers bearing front +back, Test the drive belt motor, and replace the belt if necessary.
However if the problem persist, is TIME to replace the deck belt.
God bless you
Jul 31, 2013 | Exercise & Fitness
Hi I have a second hand universal tredex treadmil, works great just stuck on the highest incline, and the lube bed stays on
Run the software calibration under the HOOD motor, and follow the steps for easy diagnose, troubleshooting, and fix it. Or see your instr. manual and goes section troubleshooting and how to enter in the s. calibration if you do not have instr. manual download free. go to
www.fitness.manualsonline.com
Please LUBE the deck belt+ rollers bearing very well.see the video
God bless you
Dec 12, 2012 | Exercise & Fitness
Rear Roller need lubrication.
see the video attached and proceed according, this is a matter very easy to lube the rollers bearing. Use the extension plastic coming the LUBE and put a little oil for lube the rollers bearint. Use WD-40 NOt use for LUBE deck belt, this 100% LUBE SILICONE special.
God bless you
Nov 26, 2012 | Exercise & Fitness
What is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Feb 09, 2011 | Horizon Fitness Horizon T103 Treadmill ...
Keeps shutting down after 20 minutes
hi
1 reason could be belt and deck(motor draws a lot of amps and belt and deck heats the motor up)
just try wax or libricate compatible lube and try (belt and deck lube you can buy from gympart.com
Nov 21, 2010 | Life Fitness T3 Treadmill with Advanced...
Lube Belt displays on digital display how to reset or where to lube the belt.
Jul 28, 2010 | Horizon Exercise & Fitness
My roger black treadmill keeps tripping the eletric
This could be a lubrication issue if this treadmill has never been serviced or worn belt/ deck. The last thing I am thinking about is if the unit is turned on with nobody on the unit and trips the the breaker then you have a shorted lower board.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
4. Lift the belt and use approximately ½ of the tube by squeezing the lube in the walking area lengthwise. Move to the opposite side of the treadmill and repeat using the remainder of the lube. Use all of the contents of a single container during application. Do not put any lubricant on any surface with which your feet make contact. The lube will spread evenly in the next step. Do not perform this step by hand. The lube is usually not harmful to the skin but has the potential to permanently stain fabric. 5. Adjust belt tension and centering following your owner’s manual instructions if you have loosened the belt to clean. LOOSENING THE WALKING BELT IS NOT NECESSARY JUST TO APPLY THE LUBE. Start the treadmill at 2-3 mph and allow to run for 5 minutes without walking on the treadmill. Check centering carefully and adjust as needed following your owner’s manual instructions. Using your treadmill’s handrails and safety switch for safety and support, walk on the treadmill at 2-3 mph. CAUTION!!! BELT MAY HESISTATE. THIS CAN CREATE AN INJURY IF BELT IS NOT PROPERLY TENSIONED! Within 5 minutes the lube will be preliminarily walked in to the backing of the belt. Damage and/or injury may occur if the belt is not properly centered and tensioned by using your owner’s manual. 5. CAUTION: Do not run on the treadmill until your are certain the belt tension and centering is correct according to your owner’s manual specifications. Make certain that there are no friction.
Go on E-Bay you may purchase a kit or a single application all of them are a silicone base lubricant so don't worry about which is the best. The application will also determine if the visual inspection and cleaning did the job and if the breaker trips then you have a belt and deck issue.
Jul 18, 2010 | Exercise & Fitness
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Exercise & Fitness Logo
146 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
