How do I hook up my wii to my olevia 237-t12 tv
  • 3 Answers
SOURCE: RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Posted on Mar 08, 2008
  • 267 Answers
SOURCE: Olevia 237-T12 Not receiving one of the digital
replace the atsc tuner or board assy.
Posted on Mar 16, 2009
ki4kmn
  • 7 Answers
SOURCE: no picture no sound
After taking the screws out and removing the back, you will see a power supply(where master switch and cord connector are). Remove the 4 screws on the aluminum cover plate to gain access to the fuse. Using a voltmeter, with the power on and switch on, measure the voltage on each side of the round fuse located just behind the cord connector. If voltage is 0, fuse is good. If voltage between 115 and 125 V, replace fuse or have fuse replaced. I think it is a 6.3Ah 250V class fuse that is soldered into the board. IF YOU ARE NOT FAMILIAR WITH SOLDERING TECHNIQUES AND PRECAUTIONS, DO NOT ATTEMPT TO DO THIS. IF YOU ARE NOT FULLY AWARE OF ALL SAFETY PRECAUTIONS NECESSARY TO MAKE THIS REPAIR HAVE A QUALIFIED TECHNICIAN DO IT FOR YOU!!!!!!
Posted on Apr 07, 2009
budmrtn
  • 11361 Answers
SOURCE: My olevia 237-t12 won't turn
It may abe in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 07, 2010
SOURCE: I have an Olevia 237-t12 hdtv, I will lose the
I had the same problem with the exact same TV. I took it to a local TV shop. My problem was fixed by replacing the T-Con controller board. The cost of the part was about $85 and labor $125. There are no "new" parts out there for Olevias because the company is out of business but I did find a part pulled from a "damaged in transit" TV. It's a personal decision (assuming the parts can be found) as to if its cost effective to repair the TV.
Posted on Sep 15, 2010
Where is the fuse for power located on a 42in olevia 237-t12 tv
At it main power regulator board inside. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 24, 2017 | Olevia Televison & Video
My olevia tv 237-T12 turns on but has no picture or sound. Screen is on but blank screen. What can I do to fix this problem
to save money take it in for a proper diagnosis and quote
that saves you chasing problems that may cost more than a shop repair or unit replacement
Sep 16, 2016 | Olevia Televison & Video
Where can I find stand for Olevia 237-t12
Hello; I would try Jimmy's parts dot com. He has tons of stuff. You can also contact Olevia for the part, but it will probably be more expensive. John
Nov 22, 2010 | Olevia 237T 37 in. LCD TV
Olevia 237 t12 has hummmmmmmm in the sound
Does the hum go away when you mute or turn down the sound completely? If it does then the issue might be one of the sources connected to it IE: DVD, Cable Box, Satellite receiver..
Nov 17, 2009 | Olevia 237T 37 in. LCD TV
What kind of bulb goes in the olevia 237-t12
LCD TV backlights, which are not user-serviceable, are a special CCFL (cold-cathode fluorrescent lamps) that is a model-specific repair part from the manufacturer. A LCD panel typically has multiple CCFL tubes, and it depends on the size of the screen.
Oct 20, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Firmware update Failed
I had the same problem with my olevia 242-T11. I flashed it with the wrong firmware and the TV would not even turn on. The blue LED light would still light up and my PC would still recognize a connection when i hooked it up to the USB cable connected to the TV.
I was fortunate to download the appropriate software. The software is called MTK_DownLoad1.exe. I know this is the correct software to use for Olevia 242-T11 and Olevia 237T. I do not know if this will work with other models.
Here is the link to the MTK_DownLoad1.exe
http://rapidshare.com/files/17475900...load1.zip.html
You will also need to install the USB to Serial driver before you are able to use the MTK Download Utility. The USB Driver is located at
http://rapidshare.com/files/17475900...river.zip.html
BE SURE ONLY TO UPDATE YOUR TV WITH THE CORRECT SOFTWARE OR YOU WILL BRICK IT. I was lucky enough to recover my TV and finally able to upgrade it to the correct firmware but my TV was non functional for about a week and this has been a huge headache and if i could go back in time i would definitely not do it so please ask yourself if its even worth it risking upgrading the firmware of a TV who parent company is reorganizing after declaring bankruptcy.
If you still want to do this, here are the firmwares for all the various Olevia models.
http://olevia.ftpaccess.cc/support/OLEVIA/
I hope this helps all the people who need to recover / unbrick their Olevia TV's. If the links are down or you need any help please ask for help in avsforums. My id is sammykismail on avsforums and i will try my best to help you.
Jun 23, 2008 | Olevia LT42HVi 42 in. LCD Television
Remote control codes
Go to Best Buy and buy the DirectTV Universal Remote Control ($20 and works with all cable and satellite services) Model RC64. It will control all the functions on the Olevia TV and Satellite box, except the A-B-C-D buttons for the User Guide.
The remote codes are:
RCA Satellite Box - 00392
Olevia 237-T12 - 11610
Enjoy
Nick from Ft. Myers
Feb 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
