Question about Exercise & Fitness
Lube Belt Universal T-3000 Treadmill
I have a T-3000 model and the display comes up with Lube Bed or Belt I have taken off front cover but cannot find were to lube and I cant seem to find any manuals about them
  • 64 Answers
SOURCE: HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Posted on Jul 27, 2009
SOURCE: Horizon CT-81 treadmill needs lube
100% Silicone Oil; 1000 weight viscosity :)
Posted on Jan 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: Lube Belt displays on digital display how to reset
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Posted on Jul 29, 2010
  • 14 Answers
SOURCE: treadmill says to lube belt,
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
Posted on Oct 25, 2010
AJIN G
  • 6694 Answers
SOURCE: Screen states Lube Belt ,
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Posted on Dec 26, 2010
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Lube Belt or Bed
see the video and fix it. God bless you
Jul 27, 2013 | Horizon Exercise & Fitness
Stex treadmill about error 2
adjust the Speed sensor, see the diagram, clean it, test for open or faulty, and tight the connector very well.
Lube the deck belt, see the video, lube the rollers bearing front+back too , test the drive belt motor and replace the belt if necessary. God bless you
However you must try to Run the software calibration after your fix it.4d80cf2e-89d9-4476-902b-88e5991886e8.gif
Jul 03, 2013 | NRS Stex 8020T Treadmill
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
White powder-like substance on belt
Dear Sir:
LUBE the deck belt, is lack of maintenance, maybe you have to change the deck belt, this produce enough friction and shut down the machine for to protect the electronic system.
2) lube THE ROLLERS bearing , according with the maintenance schedule.
3) Clean any EXCESS of wax, and LUBE very well.
4) Test the input motor if there voltage the motor need repair.
God bless you
May 09, 2012 | Proform XP CrossWalk 580 Treadmill
How to change belt
it's a big job, the front cover protecting the motor unit has to be removed, the rear roller has to be loosened inwards by using the large allen key to release the tension. The front roller has to be loosened and lifted out of the treadmill (it may need cleaned to take away any rust)
The rear roller can be lifted out and then the bed (running deck) needs unscrewed (allen keys) this should slide out. The new running belt should be put in place in the treadmill, place the front roller in place, the bed and the rear roller, fasten each of them up and adjust the rear roller so that the belt runs straight and it tight enough that when walking on it, you can't stop the belt.
Jan 17, 2012 | Life Fitness 9500HR Next Generation...
Lube Belt displays on digital display how to reset or where to lube the belt.
Jul 28, 2010 | Horizon Exercise & Fitness
Pro Form Treadmill 625 EX Wide Trac
1. You may have a worn belt and deck problem ( #1 problem on treadmills ). Test by the following procedure:
a) without the power on stand on the walking belt
b) push the belt in the direction it normally turns
c) if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction.
You must physically inspect the belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. If their is no signs of excessive wear then the next step is to lubricate the deck follow this procedure:
Before applying lubricant, the belt must have the tension reduced and cleaned deck. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. Lift the belt and slide a moist towel between belt and deck, slide the towel the length of the unit to catch the contaminants do this a number of times inspect towel and need be use a fresh towel and repeat cleaning let dry then apply the lube in the center upper third of deck then start unit and walk on it @ 1-2mph for about 5 min. You may purchase the lube from National Gym Supply @ gympart.com Part# TM001 or call them @ 1-800-496-7278 their on the west coast. At this point I believe your problem should be resolved if the above procedures have taken care of problem take a look at the next step, as mentioned the #1 cause of treadmill failure is lack of maintenance of the belt and deck.
On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem.
2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try this test:
  1. Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation.
  2. If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor. Check the speed sensor if it is a magnetic sensor unit ( Under motor shroud usually attached on the left hand side of frame with 1/8' clearance between sensor and front roller pulley) you can test continuity with a multi meter or replace with a new part to test. Many times passing a kitchen magnet in front of the signal will make a speed display on the console if the magnetic sensor is good.
May 15, 2010 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
24 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
