Rca L42wd250yx6 light flashes red repeatably when trying to turn on
    Top Expert:
  • 12,223 Answers
Open the r.control clean the keypads from dirty, corrosion, bad contacts with contacts cleaner solvent, and fix it.
same with the contacts batteries ,and put new batteries. and try again. if the problem persist you have a faulty Syscom see the diagram attached.
God bless youRca L42wd250yx6 light flashes red repeatably when - df34aea9-ddd3-4173-92f4-f811dbaaa15e.jpeg
Posted on Jul 28, 2013
Rca hdtv will not power on. Is it Power Supply or Main Board?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2015 | RCA Televison & Video
DVD Player will not power on. Indicator light flashes repeatedly.
Since the players of this kind are not repaired because of the low cost of new, just replace it.
Jul 06, 2017 | Televison & Video
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
I need code for rca tv
Hello
Codes for RCA with Innovage remote are:
000,003,004,005,
007,009,011,
015,048,082,092,
094,096,098,
101,102,103,107,
113,125,129,
167,179,187,188,
191,194
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
Feb 24, 2011 | Innovage Jumbo Remote Control
TV won't turn on, when you turn it on the green light comes on, you will see a light as if the TV wants to come on but then it shut off and the red light flashes.
You probably have some defective capacitors on the inverter board, possibly along with a blown surface mounted 10 amp fuse. If the red light flashes a particular sequence then repeats, it may indicate a specific trouble code.
Jan 29, 2011 | RCA L42WD22 42 in. LCD Television
42in Lcd RCA tv will not power on, the indicator light is flashing red 5 times then a pause then repeats
Hi Ruth, Im having the exact same problem. Ive read online that it is a fuse or something, not sure, but its the weekend, and i have no tv. Tried calling RCA cant get anything out of them. If you find out what it is please let me know. I know how frustrating it is...
Sep 21, 2010 | RCA L42WD22 42 in. LCD Television
Need codes for rca remot control have phillps tv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | RCA Universal Remote Control
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
