SOURCE: i just took my chevy aveo 2006 to get the oil
the owners manual should have info on how to reset the light. check under maitinence.
SOURCE: how do you change an oxygen sensor on 2006 chevy aveo
There is a special socket for O2 sensors which allow the wires to stick out and not get twisted up. It's not expensive and available at most auto parts stores. Disconnect the sensor from the wiring harness, with the plug and then use the socket to remove and replace the new sensor. Re-connect electrical plug.
Please rate this answer. Thank you.
SOURCE: Hi, I have a 2006 chevy aveo and I was recently
Its easy. I did mine about a month ago. You need to take off all the bolts on the top part of the motor. there are some tubes on the left side of the motor by pushing them out of the way... you take the old one off and replace it with the new one making sure its aligned and the you put it back on.. the bolts need to be hand tightened kinda as tight as you would do your tires.
SOURCE: while changing my spark plugs i found that they
Hello, this is caused by a valve cover leaking oil. you will need to replace the valve cover gasket to correct this concern.
Testimonial: "thanks"
