Question about Sharp MX-2300N Color Copier
Maintenance code f266 - Sharp MX-2300N Color Copier
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
Unlock code
You can get the unlock code for samsung f266 from your service provider or from reliable online sites like classicunlocking.com.For unlocking instructions you can visit mobileunlockguide.com , here you can get simple and step by step instructions to unlock your phone!!!
Jun 18, 2012 | Cell Phones
Fido sgh f266 password phone freeze
The phone Freeze problem. Your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone. You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
Oct 14, 2011 | Cell Phones
I cant send text messages. Keeps asking for "center number"...even though its already added in my phone. Does this more and more as time goes on. How do i send a message??!!?! Samsung F266
this is not a cellphone problem. msg center number depend on service provider. you say it's allready aded but sometimes it changed without any notice so call to custmer care and ask for msg center number enter it again and swatch off and on your phone
May 06, 2011 | Samsung SGH-E900 Cellular Phone
I can't open my bluetooth for my samsung SGH F266
if you want to open it just find wer the bluetooth in your cam
Apr 26, 2011 | Samsung Computers & Internet
Need puk code for samsug f266
When you enter a wrong pin number three times the phone asks you for a PUK number. The PUK code is generally eight digit number. This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to buy a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number. You can find the PUK code is in your SIM card documentation Starter Pack. If you do not have this then contact your phone service provider. Your cell phone service provider can give you the PUK code once they have confirmed your identity to prevent any stolen SIM access.
Mar 04, 2011 | Cell Phones
My samsung F266 phone says unregistered sim card because i took the battry and the sim out for less then 5 min so what can i do now
hi,
You will have to make sure the battery and sim card are both properly placed.This means the sim card should fit perfectly into it's slot and the battery has to lap over it perfectly as well.
If this does not work then you may try using another sim card in the phone or you try using the sim on another phone to check if it is the sim that has the fault.
most of the time it is either the sim is not properly placed or the sim card is gone bad.
Jul 31, 2010 | Cell Phones
8400 fault code
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
Sep 03, 2008 | Xerox Phaser 8400 Laser Printer
Sharp MX-2300N Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
