Question about Garden
Need help on gas lines - Garden
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Garden Master
  • 102,366 Answers
What's the problem? What make and model trimmer/edger?
Posted on Jul 27, 2013
How do I replace fuel lines on poulan lines on gas string trimmer?
You will need to purchase some new gas line of the same size as on the trimmer now and cut it to length as needed. The line will go into the gas tank and will have a fuel filter attached to the end of it.
You will need to fish the line out of the tank and put the line on the fuel filter. To thread the new line through the tank or housing it helps to cut the new line on a 45 degree angle so you can grip the line and pull it though. U tube has videos on how to do this so you can have a better idea of what you need to do. It is a little tricky sometimes. Hope this helps.
Jun 17, 2014 | Poulan Weed Eater No Pp446t 952802025 31cc...
Replacing the gas lines form the gas tank and the line to the bulb
on my husqvarna 125b the fuel line in the tank with the filter connects to the bottom of the carb. the other line coming out from the tank connects to the bottom port on the bulb. the line from the top port of the bulb connects to the top of carb. hope this will help.
Nov 24, 2012 | Garden
Hi there, I have a Weber Q 300 Natural Gas. I have an outdoor gas outlet which have been capped at the end. I don't know how to connect it to my Weber. Do I need a gas fitter to come out? Please help.
Yes, you will need a gas fitter or gas technician to complete the hookup, because the gas line has been capped and you can be sure whether or not it's still an active line. In addition, you will also need (if you don't have it already) a 12' long, rubber, quick disconnect hose the runs from the pipe to the grill (this is a Code Requirement), as well as a gas line line shutoff valve on the end of that exposed pipe, as well as all the necessary pipe fittings.
Hope this helped you. Please let me know and Happy Grilling!!
May 16, 2011 | Weber Q300 Grill
What is gas line routing Gas line broken in tank
Like the following link:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Typical 2375 IPL (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
All Poulan saws:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 31, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
A gas line is liquing
Hi my name is Tom and I am here to help you.
I am guessing that you have a gas line that is leaking. This is an easy fix. You first need to determine where the leak is coming from. You then need to cut away the damaged line from the good line.
Take the bad section to an auto parts store and ask them what rubber gas line hose would fit this size line.
I would buy about 1 foot.(It you have one leak it is a good bet you will have another. Besides you want to get in good with your parts store). You will also need to buy clamps for the line.
Place one end of the hose on one end of the gas line and one on the other.(place the clamps on before the hose goes on the line). Tighten the clamps and you are home free.
Please let me know if this was helpful to you by rating how helpful I was to you. If I can be of further help, please call or email me.
TomE
Jun 29, 2010 | 1998 Dodge Intrepid
I have a weed Eder 50 gas line i need to replace but i have to
There are two connections on the carburetor. One is the inlet and the other is a return, Check closely.
Apr 23, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Gas line leaks to rear of gas tank
You Will Need to Replace The Flex Hose & Or the "O" Ring inside it.
Jul 28, 2009 | 1992 Plymouth Grand Voyager
Gas heat radiators in the home
Not sure that I can help but will give it a go for you. I have never heard of bleeding Gas Heaters and usually they don't need that. Work on one heater at a time. If you can blow compressed air through the lines this may clear the flow. Best way is if you can get to the gas lines by removing a cover and then remove the gas line as close to the gas source. Gas heaters tend to carbon up and the air pressure tends to clear them. If you can't get to the gas lines you can try blowing the air back through the main jet at the front of the heater. Sounds to me like the jets are partially clogged and just need to be cleared. If you manage to remove the main pipe make sure you tighten it back up to avoid any gas leaks. Before trying to light it check for gas leaks as well. Hope this helps
Regards
Bryan
Jan 03, 2008 | Heating & Cooling
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
