Question about Drills
Hilti TE 17
It start doing a heavy grounding noise and you can see more than normal sparkling in the motor. What can it be and how to fix it?
    Top Expert:
  • Drills Master
  • 45,408 Answers
I t will be poling or shorting out in the armature. Take it to a motor specialist but I think you will be up for either an armature or field windings.
Posted on Aug 04, 2013
Hilti te 72 losing power when drilling
if the motor get hotter then normal this mean that the motor is coming to an end .
normally the armature or the coils of the motor starting to break down . but can be renewed , if the armature is broken that is the expensive part
Aug 01, 2017 | Hilti Drills
Need on/off switch for Hilti TE 17 Hammer Drill
Parts for the TE17 have been discontinued for over 15 years. The switches and the oilite bearings for the motor were the first to run out.
Jan 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Mar 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
Mar 05, 2010 | Hilti Drills
Hilti TE 17 Rotary Hammer repair switch fix The wirei loose how to reatach to motor?
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Oct 29, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Need rear moter bushing for TE-17
Hilti has not carried parts for the TE17 for about 15 years. That tool was produced from the 60's up until the early 80's. The part you are looking for is an Oilite bushing that is held in the motor end cap. Even though the part is no longer available a good machine shop should be able to make you one.
Oct 25, 2009 | Drills
Service light on
When the service light comes on in a normal Hilti all you need to do is replace the brushes,....however on a te-706 there are no brushes to replace, you will need to contact Hilti and have them service it.
Nov 14, 2008 | Drills
Drills Logo
138 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
