Question about Tablets & eReaders
Supersonic sc90mid unable to get tablet to unlock screen is frozen using reset did not work
nliwilson
  • 114 Answers
SOURCE: Mobits A221 tablet pc reset
You can forcibly power off the unit in exactly the same way you can any PC, hold down the power (on/off) button for 6 seconds.
Technically it's actually 4 seconds but 6 seconds gives you a margin of error. Unfortunately Microsoft make poor quality products and Windows XP Tablet Edition is no exception, Keep a a note of this procedure as this won't be the last time you need it.
Posted on Dec 04, 2007
agravante_no
  • 9 Answers
SOURCE: I have a supersonic android tablet SC-74MID is
reprogram
Posted on Apr 21, 2013
SOURCE: My brother put a password on my tablet and doesn't remember the google user I'd and password I need to restore or reset it supersonic sc-74mid 3.7v android os
Replace it or reset it
Posted on Apr 22, 2013
ercupa190
  • 12223 Answers
SOURCE: My visual land tablet is frozen on the lock
follow this steps and fix it. GOd bless you
Press the power button. Hold it for 20 seconds to force the unit to shut down.
  • 2 Turn the Tablet back on to determine if it is still frozen.
  • 3
    Remove the power adapter or USB cable from the Tablet. Turn it back off. Turn the Tablet over and remove the screw from the back of the device. Slide the battery panel off of the Tablet and pull the battery out of the unit.
  • 4
    Connect the Tablet to the power adapter and power it on. The freezing issue should be fixed and your Table should respond properly. Reinsert the battery and charge it to full before removing it from power.
  • Read more: http://www.ehow.com/how_8722116_troubleshoot-frozen-nook.html#ixzz2aUBnGy3w
    Posted on Jul 30, 2013
    spshort
    • 36 Answers
    SOURCE: supersonic 7" touch screen MID Tablet
    You need to flash new firmware you can download LiveSuit and
    then look for the correct firmware that is compatible with your tablet.
    If you search for How to Flash Tablet there will be a video or instruction on how to do it.
    Posted on Jan 15, 2014
    My tablet acts like the screen is frozen, it does not respond to touching the screen therefore I an't unlock it
    First try and hold the power button down until it switches off and then turn it back on and see if you can unlock it.
    If you can't unlock it then you can do a recovery this is how
    when it is switched off hold the volume up and the hold the power button until you see a recovery screen with options there you will see a option to recover.
    Mar 06, 2014 | Supersonic 7" Touch Screen MID Tablet
    Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
    This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
    Need tablet repair help?
    http://forum.wasatchtechies.com/
    Wasatch Techies Smartphone Tablet and Computer Repair in Utah
    Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
    Drop the tablet
    The screen probably will have to be replaced but the fall may have caused internal damage so that even with a new screen the tablet may not work without further repair.
    Dec 30, 2013 | Supersonic SC-91JB 9-inch Android 4.1...
    Tablet locked up
    You will need to do a factory reset:
    1. With the device off, press and hold Volume Up and Power.
    2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
    3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
    4. Press Volume Up continue.
    Oct 31, 2013 | Supersonic SC-90JB 9" Touchscreen Internet...
    7" supersonic tablet is stuck on the opening android screen and will not boot. The tablet's battery power went empty during the last use and was fully charged afterward.
    You'll need to do a factory reset:
    2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
    Oct 30, 2013 | Supersonic 7" Touch Screen MID Tablet
    MY SUPERSONIC ANDROID 9 IN. IS LOCKED UP PLEASE HELP!
    Oct 27, 2013 | Supersonic SC-91JB 9-inch Android 4.1...
    Supersonic tablet sc-91jb screen freeze
    When the tablet is OFF hold volume up button then switch on all the time holding the volume up button untill it boots into reset options. use vol up and down to scroll between options then power button to select.
    Jun 03, 2013 | Tablets & eReaders
    I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
    I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
    Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
    Tablets & eReaders Logo
    122 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
