Question about Samsung LN40A650A LCD TV
Flicker lcd tv jp852
Have a strobing / flickering issue with SAMSUNG MODEL LE40B530P7W...POWER SUPPLY MODEL BN44-00264C I SEARCH TO GOOGLE I FOUND MANY POSTS TO CUT JUMPER JP852 FOR SOME MODELS JP854 FOR OTHER MODELS .....I DONT FIND THIS JP NUMBERS ..CAN YOU HELP ME ???
SOURCE: samsung lcd tv keeps clicking but won't turn on
ur tv needs a new ip board u can remove the back panel and its the center main board it'll be obvious to plain site being its the only unprotected board in the tv. get the model number from the top left of the part then go to samsungparts.com enter the part number order the part.this part is only about $130-$150 dollars and ur tv should be as good as new. the ip board is a simple fix just six screws around the board and seven wireharnesses just remove insert new part and and reconnect wire harnesses to correct slot that u removed them from screw back down and ur all set no big deal. dont ask samsung or a repair man they'll just screw u over and throw u around about ten differetn loops. not gettn a straight answer other then bring it n and charge u about $600 to fix. i see alot of people have this problem so there u go simple fix guaranteed. u r welcome.
Posted on Jun 13, 2009
  • 610 Answers
SOURCE: LE46M86BD SAMSUNG LCD Picture issues (turning off after 5 secs)
you will need a tech to isolate the fault. could be power supply board or the main board but I suspect it is the lcd panel itself that is failing.
Posted on Oct 30, 2009
tvtek
  • 1284 Answers
SOURCE: i have a samsung lcd tv it flickers on and off how
There is a common issue with capacitors going bad on the power supplies in these TV's. The part number varies by the version number that is located on the sticker on the side of the TV. If you can get me the full model code and version number off of that sticker I can look up the part number and cost for you. Please take a moment to rate my answer. Thanks...
Posted on Nov 24, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 308 Answers
SOURCE: samsung ln40a530 blinking red light, no video
Blinking lights are usually an error code. Do you have a manual that will decode the number of blinks? Its not always the power supply.
Posted on Apr 21, 2010
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Why is my vizio tv flickering?
either inverter board fault or power supply fault!
Jun 07, 2014 | Vizio L32 32 in. LCD HDTV
SCREEN FLICKERING
The power supply module in this tv is part number BN44-00341A,
Samsung's dealer info says to:
For BN44-00341B; cut and remove jumper JP852.
This jumper wire is located just below the part number stamp on the pc board, I've done several of these and it cures the problem.
Jotvguy
Mar 04, 2013 | Samsung LN46C650 TV
My Samsung plasma tv is only around 4yrs old and suddenly started going from normal to dimmer projection, flickering between the two, is there a way to fix it or should I get a new tv
I have seen this in Samsung sets before, the flickering is likely a jumper in the power supply that needs to be removed, they had this issue on a number of sets---a jumper in the power supply (that board) likely is causing this, someone else here did post the location but search the model number with google for flickering and you may find it, it was widespread and as a last resort call Samsung or even a authorized service center.
I hope this helps and if you want (I spend a lot of time and effort answering questions here and if you get me the full model number I will research it when I get a chance, answer about 600 questions here a week.
Google the model number with "flickering" and I bet you can find a lot of info.
Happy holidays, Temp here is 11 degrees F right now but warm now inside the house.
Dec 19, 2012 | Televison & Video
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
My Samsung DLP TV's pictures are flickering on the regular screen, but pictures are fine in PIP mode. How do you explain that phenom?
Set uses two tuners, one for regular and one for PIP. If normal with DVD OR SOMETHING INTO REAR INPUTS, MAIN TUNER IS PROBLEM
sd tech
Aug 21, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Feb 25, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Samsung LN40A650A LCD TV Logo
199 people viewed this question
Jerry Greenberg
Jerry Greenberg
