Question about Sony MHC-GX9000 CD Shelf System
Can i connect my ipod to my old sony stereo?
Can I connect my to iPod Classic to watch video on Sony DVP-FX970 Portable DVD player? If so, what connection do I need?
The DVP-FX970 uses a composite (3xRCA) to mini-AV (2x mini-plugs) reducing cable. This is Sony part 9-885-103-56 and was included with the DVD player in the original packaging. See https://sony.encompass.com/item/7054170/Sony/9-885-103-56/Av_Cable_(010-0001-206) . Other vendors may also have the cable. You will also need an RCA (3xF) coupler, see http://www.cablestogo.com/product/40647/composite-video-stereo-audio-f-f-coupler-taa-compliant for one option. Connect the composite end of the above cable to one side of the coupler and the other side to the DVD player. Next connect the appropriate iPod Classic video dock, https://www.apple.com/shop/product/MC748AM/A/apple-composite-av-cable , to the other side of the coupler and the iPod Classic. Now, turn on everything and press the Input Select button for the DVD player multiple times until the current input is 'Line In'.
I hope this helps.
Jun 24, 2017 | Televison & Video
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
Is it possible to connect an iPOD to the Sony Receiver STR-DE598?
go hood with it an take a pair of audio rca jacks cut one end take an old head phone wire cut the end about six inches splice them hook the pos to the pos of the rca an the neg to the neg tape each one so they dont touch each other an plug the rca side into the receiver plug ur ipod or phone in an turn it to the aux mode an bamm works on car an house stereo,,,,Thats what we do at 3am an thers no where to buy a wire,,,,,,B^D l^nDz....215.....*$*$
Nov 08, 2011 | Sony STR-DE598 Receiver
Hi i have an old sony DAV-S500 stereo system and would like to set up an ipod to play through it, How do i do this? Is it even possible?
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations. You'll still have to control the music from the portable device. Oh well.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Sep 08, 2011 | Sony DAV-S500 System
Hi, We have a 18 year old Kenwood stereo which is still working perfectly and would like to plug in the ipod Touch is this possible if so how. Many thanks Nicky
"Plug in" as an iPod interface - not directly. ANYthing that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
I imagine the iPod manual speaks to that, too, somewhere.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Apple-iPod-Touch-Fourth-Gen-8GB-MP3-Players-manual/id/23867bh033/t/2/
http://www.dummies.com/how-to/content/connecting-your-ipod-to-a-home-stereo.html
Jun 19, 2011 | Audio Players & Recorders
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
I hav a Sony CDX-GT65OUI that beeps when the car shuts down. I have my IPOD connected to the stereo - made sure the ipod was shut down the USB cable removed from the stereo but it still beeps. Do you...
It beeps because it is an "alarm" that sounds because you are not supposed to leave the faceplate in the car when you get out. I read this in the manual
Jan 16, 2011 | Sony CDXGT650UI
Sony MHC-GX9000 CD Shelf System Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
