Question about Vehicle Parts & Accessories
My front drivers side tire on the inside is being tore up, I hear I need my ball joints replaced, how do I replace them, do they have to be compressed?? Or does a shop have to do it or could I do it in my own garage.
Don't rule out an alignment. if your front tires are out of tow it will eat up the inside of the tires
Posted on Jul 28, 2013
2 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: My 2008 Mazda5 is twisting from side to side when I accelerate, then let off the gas a bit.
Pulling hard seems to me that a bearing may be freezing up/going bad or a brake is not consistently releasing. Is this more noticeable as you break or is there any grinding?
Posted on Nov 13, 2012
I have excess tire wear mostly on left steer wearing the inside of the tire. this has happened to three sets of tires I also had an allignment done
Things that will tear the tires up in short order. Inner and outer tie rods, ball joints, struts/ upper ball joints( you have upper ball joints) Lower control arm bushings, bent frame, and a bad wheel bearing. Every one of these should have been caught by the alignment shop. If you replace the parts your self. Change them all. You already saved tons by doing it your self. Let me know. I will let you know how to align any vehicle by eye and test driving.
Mar 17, 2015 | 2006 Chevrolet Silverado 1500
I have a 2008 Hyundai Elantra. I have a knocking sound coming from the front driver's side. I notice it most when I am braking, but I just had all my pads and rotors replaced 10 months ago, and don't...
sounds like a suspension rubber or a ball joint gone bad, they should have picked up a worn ball joint during the wheel alignment, but not all aligner's are alike
Sep 06, 2013 | Hyundai Cars & Trucks
How do you tell if your ball joints or bushings are bad
Best Answer - Chosen by AskerWhat is the difference between control arms bushions and ball joints. There is a big difference between the two and the job they do. The bushion conect the control arms to the fram. There are two bushion per control arms. So there is a total of four per front wheel. Two for the upper control arm and two per lower control arm. It let's the vehicle go up and down. And is the back half of the the system that hold the coil spring in place with the two control arms. The ball joint are known as upper and lower ball joint. So you have two ball joints per front wheel. They hook in to the outter end's of the control arms. And hook to the top and botton of the spinner. They allow you to trun the wheel's to the left and right. Along with the spinner hole the outter side of the control arms to hole the coil springs in place. Putting the spring under pressure. In small a Srud is used and takes the place of the bushion's and ball joint's.
What has play in it? There should be some play but you should be able to move it by hand. Most ball joint's can be lubbed. If it still has play of a 1/4 inch it should be replaced. A really bad ball joint can pull out of the socket. This will cause the wheel go up in the fencer well. If the top one brakes loose the wheel will lay down. That is the danagous of the ball joint giving away. It will be hard to control the car to a stop. The bushion's will let moving of the part and wear out the front tires really fash.
I know you don't care to hear this. The car should go to a front end shop. Where they have the special tools to do the job safety. Pluse can line the vehicle back up. When it will need. It be cheaper than a roll over.
Source(s):
ASE & Master Mechanic
Feb 11, 2013 | Cars & Trucks
1990 oldsmobile delta 88 royale brougham. When The engine is running you can hardly hear it. It runs great, and sounds good... Until you start driving at higher speeds. It starts around 20 kmh and will...
could be ball joint but I suspect that the problem is wheel alignment from a failing wheel bearing
inside tyre wear indicates toe out problem, wheel with negative camber or a steel belt moving problem under the tread
best take it to an accredited front end specialist shop for a proper diagnosis and quote
May 04, 2017 | Cars & Trucks
Do the ball joints come out of the drag link and tyerod and if so how? 84 Holden shuttle bus.
well first off the ball joints dont connect to either the tie rods or the drag link ...if you are refering to if the tie rods are rebuildable they come as a new complete piece
Mar 01, 2011 | Ball Joint, Tie Rod, Pitman Arm Seperator...
Have a 2002 chevy silverado 2wd that is making a popping noise when I turn left or right and has vibration going down highway. Noticed that grease boot on driver side ball joint was busted and was...
It is possible that the ball joint is bad, to check you can jack the wheel up 1/2 off the pavement and use a tire iron to lift up and on the tire and watch the ball joint if it moves up and down thats your problem. from a mechanics point of view I would replace both the top and bottom at the same time as this saves labor since you have to tear it down anyway and the upper ball joint should be worn as well. If the ball joint does not move then put your hands on each side of the tire and move it back and forth, if you get movement you will need to get a second person to move the tire back and forth and watch to see where the play is. normally it will be in the drag link or the control rod, replace items as needed and try for free play again, you may find another bad part as well. normally there is more than on failed part. once you have done the parts replacement you can put a scratch in the tire with a nail on each front tire and then with a tape measure measure the front and back of the front tire you will want to get it toed in 1/8 of an inch then go to a tire shop for a alignment. should be around 58 inch's center so front would be 57 inch's and 15/16 this of an inch and the back would be 58 inch's and 1/16 of an inch. hope this helps. If it does please rate and thanks for using fix-ya.
Oct 06, 2010 | 2002 Chevrolet Silverado
When i make right or left turns beneath my driver side i hear a thumping/pulling sound
there is a numer of things tha cause this bad ball joints tie rod ends for loose wheel bearings try this get the front end of the truck off the ground take a long bar pipe and place it under the tire if the tire move up and down replace the ball joints or my way take a big pair so channel locks and try move the ball joints up and down also try this on your tie rod ends. to check for loose wheel bearing try moving the tire side to side if you can fill play replace the wheel bearings and seal.
Jul 01, 2010 | 2004 Ford Explorer
Clunking in tire
check ball joints by lifting front end and shake tires. if loose your ball joints are bad. you will hear a clunking sound as you apply brakes during driving. its the play in the ball joint. the dealer wants $600 in labor. $160 in parts at auto zone. get the ball joint press also. good luck.
Jan 27, 2009 | 2003 Ford F250 Super Duty Crew Cab
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
