Question about Sewing Machines
Janome juno 3434d will turn on, but won't run, when you press the foot...
I have unplugged and replugged and even changed outlets and still will not run...it lights up and the handwheel will turn when doing it manually, but when you press the foot, it does NOTHING!J
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
bargainbox
  • 1388 Answers
SOURCE: I have a Pfaff 2046. When I press down on the
Probably the belt tension needs adjusting, it is slipping like a car fanbelt and needs the same relative "give" when correctly tightened.
Remove the side cover where the handwheel is and loosen the motor fixing to adjust and increase the tension on the belt ....needs some slack, if you can move the belt 10mm with light pressure then it will be fine NOT TOO TIGHT or you will overload the motor. NOTE: If the side panel is not easily removed, ie 2 piece casing split in the middle, take it to a service centre or risk breaking the casing trying to get in....if it is more than a few years since last service, let someone do it all and get a sweet machine back, with no risk for not a whole lot of time or money
Posted on Aug 27, 2009
Testimonial: "Thanks! I think I'll zip it in to the service center."
SOURCE: i have a juno by janome 3434d serger. when i
Whenever I've had an issue with threads breaking, it's usually the tension or it's not threaded right. You probably have the first thread lapping over one of the bottom threads it shouldn't be lapped over. I would suggest you put all of your tensions back at factory level, pull out all the threads and rethread the whole thing. Thread the two bottom ones first without moving the handwheel. (Make sure the handwheel has the two top needle in the up position. When you thread this machine, you must not have to turn the handwheel. If you do, you change something.) Then thread the top needles. After that hold all four threads and make a string. Test on the same type of fabric as what you're working with. Adjust tension as needed. HTH
SharonH
Posted on Oct 12, 2010
SOURCE: janome j3-20 suddenly stopped working
I would suggest taking the machine in to be checked
Posted on Jun 08, 2012
SOURCE: My Juno janome serger 3434d upper looper and lower looper keep jamming into each other.
it sounds like the serger needs to be checked to see if it's out of
time, at a sewing machine shop
Posted on Sep 24, 2012
I am looking for the instruction manual of the janome v 74088 619
Search the internet for:
Make + Model + the word "Manual"
Feb 29, 2016 | Janome Sewing Machines
I need a manuel janome serger 3434d
try this link for the manual and parts
Janome 3434D Parts
Aug 25, 2014 | Sewing Machines
Janome Juno 3434d wont make a chain
If it was hitting before you stopped, it's likely that the looper either got bent or was knocked out of time. I would take it in for repair.
Dec 23, 2012 | Sewing Machines
Sep 23, 2012 | Janome 6019QC Mechanical Sewing Machine
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
I have a Janome DC 2010. The machine has started to continue to sew even when my foot is off the foot control. I turn the machine off and then back on and it goes to error message fc....then goes to...
my book show the FC stands for Foot Control
have you tryed repluging the foot control into the machine to see if that stops the problem
if you have & it didn't stop the problem
then I agree you need a new foot control
Sep 27, 2010 | Janome 2049LX Mechanical Sewing Machine
I have a juno by janome 3434d serger. when i ruffle, the first thread keeps breaking and it will not ruffle correctly. what can i do?
SharonH
Aug 31, 2010 | Janome Sewing Machines
Janome 5124 keeps running after I depress foot
Greetings, I experienced the same problem. Mine only ran a few stitches. Foot pressure on the foot feed was always "tension" problem in my foot.
I turned the foot feed around and upside down.
I press on the foot feed at the open end not the pivot (cord) end. This has given me much better control. Janome had no options for foot feed adjustment or replacement, but this has helped greatly. You may have to practice to get used to it
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
