Removing Cd Player triton 2013
How to remove cd out of dash mitsubishi triton2013
SOURCE: '06 Nissan Murano factory radio/cd player removal steps
what holds the radio in place besides the 2 side screws in a 2006 nissan murano
Posted on Feb 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: Steps to remove radio
  • Step 1:Disconnect the negative cable from the battery terminal. Position the cable to is doesn't come in contact with any metal parts.
  • Step 2:Pull out the ashtray and remove the two screws that connect the bezel around the radio. Pull off the climate control knobs and remove the two screws at the top of the bezel trim.
  • Step 3:Remove the trim and disconnecting any wires. Not all models will have connecting wires on the trim.
  • Step 4:Locate the two screws, one on each side of the Hyundai Santa Fe stereo, and pull the head unit out of the dash. Disconnect the wires behind the radio.
  • Thanks for using FixYa - a FixYa rating is appreciated!!
    Posted on Feb 20, 2009
    • 30 Answers
    SOURCE: cd stuck in player how do i remove cd player from dash
    start with the screws on the bottom of the stereo..they are located on the area above the shift knob where you could place misc items compartment.
    Posted on May 24, 2009
    localwonder
    • 6784 Answers
    SOURCE: I have a CD that will not eject from my car CD
    This will not be easy. the actual loading track motor and track assembly has become stripped and, you will need to disassemble the unit in order to extract the trapped CD in this case.
    Unfortunately, there is no escape button on this particular unit.
    Posted on Jun 19, 2009
    mindreader
    • 578 Answers
    SOURCE: I have a '05 Ford Fusion and it has a CD stuck in
    Not sure of the manufacturer - but most have a small pin hole near the CD insert slot - inserting a straightened paper clip into that hole a few times will often eject the CD. Good Luck - and let us know ....
    Posted on Oct 10, 2009
    How do i remove the cd player from pajero io 1999
    You may have to remove the dash board to get access. If mounted on center console then that has to be removed.
    Mar 10, 2016 | 2001 Mitsubishi Pajero
    I need the unlock code for 2013 mitsubishi triton
    I also went this website to find out what numbers i needed and they emailed me my code. Just for those who might have wanted it! https://www.mitsubishicars.com/owners/support/radio-code
    Mar 10, 2015 | Mitsubishi Cars & Trucks
    Spark plug gap for 1997 mitsubishi trition 2.4 petrol ute
    Spark plug gap does not effect the engine timing so it's not that critical. Thirty 5 (.035) should work just fine.
    Otherwise consult a service manual fro your model or call a Mitsubishi service centre
    mitsubishi triton service manual
    Mitsubishi Triton L200 2006 2013 Workshop Manuals Factory Service Manuals
    May 27, 2014 | Mitsubishi Pickup Cars & Trucks
    I have a 2005 Ford 500. I have twoo CD"S stuck in the player. How do I remove them?
    If the two cd's which are stuck, if you can see that cd's then pull the cd with pliers.Its a two mouth pliers to pull the things out.The cd may get cracked/ break while removing.But if the cd's are not seen or its very hard stuck, then in that case.The cd player has to be removed out of dash.Yes it will be time consuming, and will not be very simple.But once the player is out, its not much to do.The cd player bottom has few screws to be removed.Once you remove the screws, the complete top assembly will get lifted.You can say" complete casing" will be lifted.Once the casing is out.You will visually see the cd, and you can manually slide the cd out and remove it.---------- ---------- Click this link for cd player removing procedure from dash :--------- http://whoisbyme.blogspot.com/2011/08/how-to-remove-cd-player-from-dash-of.html ----------- This will help.Thanks.Helpmech.
    Aug 03, 2011 | Ford Five Hundred Cars & Trucks
    How to install cd player in my 97 eagle talon
    use radio keys local radio shop might have them 2 types slots or holes in your radio
    Apr 02, 2010 | 1997 Mitsubishi Eclipse
    I have a cd stuck in the cd player. help.......2005 vw beetle
    grab some hemostats and probe the middle of the slot for the cd's edge. Clamp and pull.
    The only option other than reaching in a grabbing the disk would be to remove the entire middle dash panel by systematically removing all bolts, removing the cd player, opening the top of the unit and "plucking" the disk out, only thing is you are likely to continue having this problem unless the unit is replaced or you found something obstructing the disks path the you where able to remove.
    Feb 22, 2010 | 2006 Volkswagen New Beetle
    Removing a CD player from a 2001 Mitsubishi Mirage?
    Don't know how much this will help, but some factory radios have a tool that is shaped like a big staple and there is 2 of them. If you see 2 small round holes on the sides of your factory cd player, then thats where these tools go. I have seen them at Wal-Mart and at Autozone. I have mainly seen these on Ford cars, so I'm not sure about a Mirage. Hope it helps.
    Dec 31, 2009 | 2001 Mitsubishi Mirage
    Unlock code for car cd player
    If you can not find you ode in your trucks Owners Information under CD, Contact your Mitsubishi dealer with VIN# on the lower edge of your windscreen nd they should be able to retrieve the code from the VIN when you are given the code enter it with the station preset buttons. Best of Luck
    Jul 15, 2009 | Car Audio & Video
    My cd player will not accept cd's (the tray inside will not come down) so I think I'll have to buy one from a salvage car - Question is (1)any thoughts on fixing the existing cd (2) how would I go about...
    REMOVE THE RADIO FUSE FOR ABOUT 30 SECONDS THIS MAY RESET THE RADIO/CD PLAYER.
    IF YOU DO INSTALL ANOTHER RADIO IT WILL HAVE TO BE PROGRAMMED AT A DEALER.
    REMOVE THE COVERS ON THE SIDES OF THE DASH.
    REMOVE THE GLOVE BOX ASSEMBLY.
    REMOVE THE KNEE BOLSTER UNDER THE STEERING COLUMN.
    PUT ON THE PARK BRAKE AND SHIFT THE CAR INTO NEUTRAL.
    REMOVE THE BEZEL AROUND THE RADIO, CHECK THE LOWER CORNERS FOR SCREWS, PULL OUT CAREFULLY ON THE BEZEL.
    REMOVE THE RADIO.
    Jul 12, 2009 | 2006 Pontiac G6
    Removal from dash of a 1989 dodge colt
    Unsnap the trim ring and you will see a slot in the center of each side. Insert a pair of Pioneer radio removal keys which any Car Audio shop should have lying around and will probably give you for free.
    Sep 11, 2007 | Pioneer DEH-P3700MP CD Player
     Grubhead
    Grubhead
