Question about Refrigerators
N Finity 121 Model 273 02 21 03
This unit will not respond to the on/off switch. Power at the receptacle is good.
  • tcnine
    tcnine Sep 10, 2015
    Same model no. Same problem.
3 Suggested Answers
refritech08
  • 149 Answers
SOURCE: maytag M7D24E7B
if unit has electronic controls, verify that the fuse/s ain't blown. also check wire connections probably a broken wire from main source.
Posted on Apr 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Model MHV350E....replacing lamps and shorted-out....power
Whenever the cooktop lamps blow or when they are removed or installed while the oven has power, the filaments can internally short, causing a surge which can blow the microwave's fuse and damage the circuit board.
I would suggest that you first check and replace the fuse in the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If replacing the fuse does not restore all functions, we regularly repair these controller assemblies nationwide by mail for $39.95 postpaid with a one-year guarantee.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on Dec 12, 2010
Keurig won't turn on
First of all, plug a different appliance into the receptacle to see if that is not the problem. If it is, go check your breaker. Secondly, if the receptacle does work plug your Keurig back in and turn it on using the switch in the back of the unit. Feel the switch to see if it 'rocks' back and forth with a bit of pressure. If it moves easily the switch may be bad. If you have access to a 'Fluke 2AC 90-1000V Volt Alert Non-Contact Voltage Detector Pen Tester LED' ($25.00) or some other type of voltage detector run it along the cord from the receptacle (while plugged in) to the base of the pot and see if you have power. From there take the base-plate off (unit unplugged) to the point that you can see where the cord ties into the Keurigs cord. Plug the cord back into the receptacle and check your voltage again, this time before and after the switch. If you have power after the switch with the unit turned on then there is a good chance the units pump is burnt out. You can find them on ebay, easy to change out. If there isn't any power then jumper across the switch to see what happens. Lots of Luck.
Mar 15, 2014 | Keurig Coffee Makers & Espresso Machines
I have an existing 2 double receptacles and I'm adding a third single receptacle with a switch on it. Do I have to get my source of power to my switch or to my receptacle?
i think you want to use this as a trun off for you switch, run the power to switch then to the plug this will let you turn your plug on or off, good luck
Aug 06, 2011 | Electrical Supplies
How do I hook up a amp to a Superstar 121 cb radio
first if must be adjusted for deadkey to be lowered down from 1-4watts as not to hurt the amplifier, then connect a small jumper to the amp, run heavy gauge wires to a good power source hopefully the battery.. just use a relay to switch on/off w/key/stereo circuit to turn main power off the the amp. if need too. Also the SWR's must be low have them checked. Free @ any Good Radio Shop.
Mar 10, 2011 | Superstar SS-121 120-Channels Base CB...
Can't get my switch to operate the outlet just bought a 5625 switch i have two wires coming out of the wall i want to plug a light in the outlet and have the switch control the power to the outlet.
  • Turn off the power to the receptacle that will be replaced by switching off the circuit breaker in the fuse box. Check that the battery is good in a circuit tester. If not, replace the battery. Place the tester's two ends in one set of the receptacle's slots, then the other set. The light on the tester should not come on. If it does, the correct circuit breaker has not been switched off.
  • 2
    Take off the receptacle's face plate by first removing its screw. Detach the two screw securing the receptacle to the box and pull out the receptacle. Loosen the receptacle's terminal screws and pull away all wires from the back of the receptacle. Take out the receptacle (if working properly, it can be reused). If the ends of the wires are chewed up after removing them from the existing receptacle, cut them off with wire cutters. Strip off 1/2 an inch of insulation from the ends, using wire strippers. Bend them into loops with the pliers.
  • 3
    Bend the copper ends of all wires into a loop, using a pliers. Connect the white wires to the silver terminal and tighten the screw to the wires. Connect the black wires to the gold terminal and tighten the screw to the wires. Connect the bare ground wires to the ground terminal and tighten the screw to the wires.
  • 4
    Push all cables into the back of the box, followed by the receptacle. Attach the receptacle to the box with the two screws. Hold the new faceplate in position and install the screw. Turn on the power at the circuit breaker.
  • HOPE THIS HELPS YOU...Jim...Please leave a comment
    Feb 13, 2011 | Leviton Electrical Supplies
    Want to install a duplex switch in a double gang box that currently has a receptical and a single switch. The existing single switch is wired in a switch loop and operates a switched receptacle. I would...
    So you're replacing the receptacle in the 2 gang box with a switch that will control a receptacle? If so there's no reason you couldn't use the feed from the receptacle. As long as you maintain the integrity of any existing runs through the box...you're not adding any devices really so there shouldn't be a problem with the branch circuit device count. Bear in mind this stuff has the potential to burn your house down so be real clear on what you're doing and make a good secure job of it. When in doubt call in a pro....
    Dec 09, 2010 | Leviton 5224-2 Wall Duplex Switch
    The tower nor keyboard wont come on and its pluged in
    Advise, c
    1) Check to make sure THE receptacle in the surge protector that the computer is plugged into, is good.
    I have had a few surge protectors where just THAT receptacle was bad.
    ("Hmmm, monitor, router, and printer has power from the surge protector." Checked the receptacle in the surge protector that the computer was plugged into, with a table lamp, found THAT receptacle was bad)
    2) Receptacle in surge protector proves to be good?
    Suggest performing the test to see if the problem is the Power On switch, or the Power Supply.
    (The Power On switch is located inside the plastic Power On button)
    The test involves bypassing the Power On switch, by using a jumper wire on the Soft Power On, in the ATX main power cable's connector.
    Has nothing to physically do with the switch itself.
    Using the jumper wire the computer (Power Supply) comes on?
    Problem is the Power On switch.
    [ Example of a generic ATX power on switch that I have found fits many computers,
    http://www.directron.com/atxswitch.html ]
    Using the jumper wire the computer (Power Supply actually), does Not come on?
    The problem is the Power Supply.
    Replace.
    http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
    (Green wire {PS_ON} is the Soft Power On wire. It is jumped to ANY Ground {Black} wire)
    Want to know how to Properly perform the above test? Please post back in a Comment.
    Also post the computer manufacturer's name, and the Model Number.
    (On the back of a desktop computer next to the Windows Product Key, or up on the side of the tower)
    Regards,
    joecoolvette.
    Nov 08, 2010 | Computers & Internet
    No power cannot turn on
    Suggest you check the simple stuff first.
    Not checking is akin to a car that won't start, and tearing apart the entire fuel system, only to find it was just out of gas.
    1) Make sure the receptacle the surge protector is plugged into, has power. Surge protector Power On light should be lit.
    2) Check THE receptacle in the surge protector, that the computer itself, is plugged into.
    Have had a number of expense surge protectors, where just THAT receptacle was bad.
    ("Hmmm, surge protector Power On LED light is lit. Monitor, printer, sound system, and router plugged into the surge protector has power. Should be good to go.
    NOT!
    Plug a table lamp, or similar device into THAT receptacle.
    Make SURE it has power)
    Surge protector, and receptacle in surge protector checks out?
    Bypass the Power On switch.
    See if the problem is a $5 Power On switch, or the Power Supply.
    (Generic ATX Power On switch that I have found fits many computers,
    {The Power On switch, is located inside the plastic Power On button assembly}
    This is information about computer Power Supply's,
    http://en.wikipedia.org/wiki/Computer_power_supply
    This is a basic example of an SMPS, (Photo at upper right. You can click on the photo to enlarge), and info about.
    (Switched-Mode Power Supply. The main type of power supply used in personal computers),
    http://en.wikipedia.org/wiki/Switched-mode_power_supply
    By bypassing the Power On switch, you will be able to determine if the problem is the switch, or Power Supply.
    Bypassing the Power On switch turns the Power Supply on?
    Bad Power On switch.
    Bypassing the Power On switch does Not turn the Power Supply on?
    Bad Power Supply.
    A jumper wire is used on the 20, or 24-pin ATX main power cable.
    The jumper wire goes to the Soft Power On, (PS_ON. Green in color), to ANY Ground wire.
    (ALL Black wires are Ground wires)
    A MOMENTARY contact is used.
    (Example of a 24-pin ATX main power cable, and it's respective connector,
    http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24 )
    In order to guide you in this procedure, I need to know the computer manufacturer name, and Model Number.
    On a desktop computer this will be located on the Back of the computer tower, (Next to the Windows product key), or up on the side of the tower.
    Some models have it where there is a door you open in the front, and the product number, or model number is located there.
    Post back in a Comment.
    Aug 07, 2010 | HP Computers & Internet
    AC unit LWHD 1800R won't turn on & test/reset does not respond.
    Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
    Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
    Unit starts with auto throttle off. engaging auto throttle shuts down unit. in past months, pluging in a cord would shut down unit. That is with no tool in use, just plugging into the receptacle.
    Hi. There are 2 things that control the Auto Throttle and that is the idle control valve (Connected with black and yellow wires) and the Auto Throttle Unit.
    Start Generator
    Check for 12VDC on the Yellow wire of the idle control valve. Yellow is positive to any good Chassis ground. If you don't have 12VDC then either the Auto Throttle switch is bad or the Auto Throttle Unit iself.
    You can gain access to the Auto throttle switch and again check for 12VDC to Ground on both sides of the switch with the switch on. (It may read as high as 13.8 engine running) If you don't get 12 - 13.8 VDC the the Auto throttle control unit is bad
    If you have 12VDC to the Idle control Valve and it does not work perform a resistance check across the coil of the Idle control Valve (both wires disconnected Engine off) Black to yellow should read 3 to 4 Ohms If you have no resistance then the coil in the Idle control Valve is bad.
    If you need more help just respond here
    Kelly
    Feb 09, 2010 | Honda 3000 Watt Portable Generator
    Half of a dual receptacle outlet is not working, the other recepacle in the outlet works fine. It is not switched to a light switch, and the breakser never trips when I use the receptacle that works....
    This is fixable but not by a computer tech. You will need to take this unit to a place that does TV's and other electronic repairs. They will best best at correcting this type of issue. Most techs will say just replace the unit.
    Thanks,
    MyLive-Tech 1-888-361-8511
    http://www.mylive-tech.com
    Jan 29, 2010 | APC MasterSwitch Power Receptacle - Power...
    Refrigerators Logo
    75 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
