Question about Bryant 463AAC008BA Air Conditioner
Bryant ac motor 566bb00240000e00 - Bryant 463AAC008BA Air Conditioner
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
Fan not moving on Bryant 113R AC Unit
bad relay, capacitor, fan motor froze up, try turning by hand.
Jun 11, 2014 | Bryant 463AAC008BA Air Conditioner
Bryant condenser not running.
Check that there's power available (open or tripped breaker or disconnect). If there's power available, check for 24-28 volts feeding the contactor coil. The low refrigerant cut-out may have tripped the 24v (leak). The pressure cut-out may have tripped (dirty condenser coil, inoperable condenser fan motor). If there's 24 volts at the contactor coil, check the capacitor before ohming the motor. A defective run capacitor will shut the compressor down.
Aug 27, 2013 | Bryant Legacy 16 Series 4.0 ton AC...
Ac squirrel cage fan motor noise
Could be bearings going out, or a squirrel cage rubbing the blower housing, a squirrel cage blade that came loose, or a capacitor.
Jun 12, 2012 | Bryant Heating & Cooling
Bryant ac inside fan motor is loud
motor going bad or squirrel cage dirty or bad.
Bryant 557A fan blower not working. tech shows up and says need new fan motor. goes back to shop and owner of ac business calls and says he wants to recheck. comes back and puts test set on ...says new...
Is it burning up the motor or the control module?
If its the module the motor is probably running at full speed all the time. They need to check the wiring, duct static, filters, coil, any restrictions to airflow.
It might be a good idea to have them check with the Bryant customer service technicians or hot line. They deal with these problems all the time.
Dec 13, 2009 | Heating & Cooling
What is the part number for the outdoor fan motor?
as old as this unit is you probably cannot read the label on the motor it is either a 1/4 or 1/3 horse power 230 volt motor. a generic motor will work fine, use a 1/3 to be sure. also replace the capacitor so it matches the new motor. if you can read the label the part number is on it, should be an HK # with about 7 more digits
Aug 03, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
