Question about Crosley 40-pint Dehumidifier
Crosley 70-pint Dehumdifier high-pitched whining
I just purchased the 70 pint Crosley dehumidifier, model number cdf700w1...I let it acclimate to room temperature for four hours. When I turned it on the fan sounded nice and quiet....however once the compressor kicked on it made and continues to make a high-pitched whining noise. This does not sound like a good thing. I left a message for the appliance vendor, but have not heard back yet. Is this common for this type of dehumidifier? My GE never made this noise, although it stopped working after one season. The Crosley is collecting water but I cannot stand the high-pitched whine. I am afraid to leave it unattended....any advice?
4 Suggested Answers
  • 5 Answers
SOURCE: Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
Posted on Oct 26, 2007
heatman101
  • 43501 Answers
SOURCE: Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 14, 2010
  • 4736 Answers
SOURCE: I have a Crosley Model
It may very well be that you have the humidity extraction level set to high. Lower it to 32-35%. If you have a manual unit, set the control to Maximum. Since it's a basement application, raising the unit up off the floor on to a sturdy table or counter top that can handle the weight of the unit, plus a full bucket of water, may also solve the problem. As, the air temp at floor level is colder than at chest or shoulder level. Dehumidifiers do not work well at temperatures between 40 - 60 degrees F. Unless you have what's called a Low Temp Model. They are specifically designed for basement applications.
Hope this helped you to troubleshoot and solve the problem
Posted on Jul 03, 2011
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
We just bought the DE45EJ. We removed it from the box and plugged it in....nothing. No lights, no beeps, no hint of life. The power source is good. The room temperature is normal. The bucket isn't full...
If you just purchased and it won't turn ON, don't waste time trying to fix the unit. Return it to the place of purchase for a replacement unit or a refund.
Thanks for choosing FixYa.
Sep 10, 2011 | Haier 45-Pint Dehumidifier
Why is my dehumidifier icing up.
The room temperature is probably too cold, or there's poor airflow
Here's some info that should help you figure out what's causing the problem:
If the evaporator coil is frosting completely and evenly, the most common cause is that the room temperature is too cold. Most dehumidifiers are not meant to be used when the room temperature drops much below 70°F and certainly not below 65°F (depending on humidity). There are however some models called "basement" dehumidifiers which are.
Another possible cause on standard models is poor air flow through the unit. If the fan motor is not turning fast enough (or at all) or the evaporator, condenser or filter (if used) being plugged can also cause this symptom .
May 13, 2011 | Goldstar DH304 Dehumidifier
Need float switch that cuts off dehumidifer when bucket gets full
Without a Model Number or Part Number it's hard to help you. But here are three links, where you can find the float switch, if it's still available. You'll definitely need the Model Number to find anything.
http://www.apwagner.com/index.php?main_page=page&id=148
http://www.appliancepartspros.com/crosley-dehumidifier-parts.aspx
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Crosley&Term=crosley+dehumidifier+parts&gclid=CIzJ3ZvR4KgCFcV95Qodnh3C0g
Hope this helepd you. Please let me know. Thanks.
May 11, 2011 | Crosley 40-pint Dehumidifier
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Crosley 40-pint Dehumidifier Logo
95 people viewed this question
Top Crosley Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
